Script Guide Installation Crashes
catplace
motherboard: Gigabyte GA-P67A-UD4-B3
processor: Core i7-2600K
Video Card: nVidia 570
sound_card: Soundblaster Fatality
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung B2440
Post by catplace »
Hi. I've just installed X7 (not ultimate)—except for PSPX7_ScriptGuide.exe, which crashes (see attached images).
Installation of all other X7 components went fine. The software is registered.
I redownloaded the offending file three times (from two different locations). File size is 7,262,944 bytes.
I tried to run the file on three separate computers (two are Win7-64; one is Vista-32), with exactly the same result on all.
I tried installing in safe mode. Same result.
I tried disabling the firewall and anti-virus. Same result.
I'm thinking that the file is defective. Has anybody got it to install successfully? Is there anything else I can try?
Thanks!
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: Script Guide Installation Crashes
Post by Radim »
File - PSPX7_ScriptGuide.exe, size: 7 262 944 bytes.
MD5: 66537A9273EDA2A2A541160A94DD8FF7
SHA1: 3394B45345245DB3CBB977A555471060937D7679
If you still have problems with installation, here is an installed folder az ZIP archive - http://leteckaposta.cz/626254261
catplace
Post by catplace »
Wow, thanks Radim! :)
I definitely had the correct file. It's just a mystery why it won't install on ANY of my computers.
I downloaded the .zip and it seems fine. I note that it's only about one-tenth the size of the .exe, even after unpacking. Perhaps the rest of the .exe is just installation code. Is that your belief?
Many thanks again; I'm most grateful for your help.
