DMF_temp
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
DMF_temp
In my documents in corel video s tudioo folder creating after installation of VS a folder called DMF_TEMP wtih 28 GB.the folder and the capcity are ''normal"?i found know that when i create a vide with share option ,somehow create and a second duplicate file which saved in DMF_TEMP file.why happened that?how can i s top?
Re: DMF_temp
Hi vasilis
The DMP_Temp folder is required to store temporary files created mainly when using the Burner Module, these are required for a successful burn, you can change the location of the working folder by pressing F6 when in the burner module.
The files are created when converting the project to a video file, (convert title stage) this is then used to burn a disc.
If you created a compliant video file from Share Create a Video File, used that to burn a disc, the convert Title step would not be required and the temp files would not be created.
As the folder name suggests these are Temp files and can be removed.
They may be created again when burning a disc.
From the last window, above the Burn button is a small icon containing a “disc and bin” that will delete temp files
