Can I render/export just a PORTION of my project?
wsalopek
Hard_Drive_Capacity: 1TB
Post by wsalopek »
Hi folks,
I have a 1-hour-ish video containing several musical performances. I'd like to render X minutes at a time (one render for each of the several performances), so that I can then upload those individual performances to YouTube as separate videos.
Is there a way to do that? Like..."render from mark in to mark out"...something like that?
If not, what is the best way to accomplish what I am trying to do?
Thanks...
Bill
Re: Can I render/export just a PORTION of my project?
Post by BrianCee »
Yes - exactly that - - render from Mark in to Mark out only
Open your project in VideoStudio - look immediately under the preview window at a white line with orange sliders under it - using your mouse click on the left one and while holding the key down slide right to the point where you want the particular movie to start - an orange line will appear over the timeline - now slide the right hand slider left until it is where you want the movie to end - orange line ends at second slider
you can if you want now test play your movie as it will only play where the orange line is - so you can check beginning and end are where you want them
Now go to "Share >> 'Computer file' >> video format (mpeg etc)"
now look at the bottom of that screen to the left of the 'Start' button to a little box next to "create preview range only" click the little box to put a tick in it - then click 'Start' - VideoStudio will allow you to name the file and then create a video file of just the selected portion.
When it completes go back to the 'Edit' screen and move the orange sliders to new positions and go through the procedure again
keep repeating until you have all the videos you want.
When finished don't forget to move the orange sliders back to their respective ends of the white line.
wsalopek
Post by wsalopek »
Thanks so much Brian.
Terrific.
Bill
