Corel Videostudio Pro X7: Audio cuts out :c
SuperJimbles
- motherboard: Gigabyte
- processor: Intel i5 4750
- Video Card: GTX 760
- sound_card: Onboard
- Hard_Drive_Capacity: 822gb
Heyo, me again c:
For some reason, I've been trying to record stuff, but and random points through out each video, the audio cuts out, and doesn't come back. I know this is the editor because if I just listen to the raw footage, then it plays out fine.
SuperJimbles
Re: Corel Videostudio Pro X7: Audio cuts out :c
Sorry but I don’t understand what you are doing, can you explain a little more
1 / What does “Record Stuff” mean????? Do you mean capturing video?
2 /Any cameras involved, what type?....maybe connected to USB device, DV Mini camcorder
3 / With the video on the timeline, right click and choose properties what are they?
4 / or maybe you are using the screen capture option.
We need more information to give sensible replies...........
Carson77
- motherboard: ASUS M5A99FX PRO R2.0
- processor: AMD FX-8350
- Video Card: Nvidia 770GTX
- Hard_Drive_Capacity: 500GB SSD
I am having this problem as well. The audio plays fine and then after a random amount of time ( I seemed to notice at least 3 minutes into the video) I lost audio all of the sudden in the video editor. It plays audio just fine outside the editor. I capture my videos using the Nvidia ShadowPlay. It does a full desktop capture.
Video type: H.264 High Profile Video
Attributes: 24 bits, 1920 x 1080, 16:9
Frame rate: 60
Audio Type: MPEG AAC Audio
Attributes: 48000Hz, 16Bit, Stereo
Bit rate: 192 Kbps
Frame rate: 60
Bit rate: 192 Kbps
Hi Carson
welcome to the forums...
First thoughts
try setting your project properties to use 60fps, editing one of the AVCHD templates should allow that frame rate.
First thoughts
Carson77
I changed the Project Properties to the suggested 59(60) fps, however it still did not help my problem. I have tried looking around and can not find a solution.
Maybe the VideoStudio just does not do well with videos recorded using the Nvidia Shadowplay feature. Everything else seems fine besides the random audio loss, gets cut out.
SuperJimbles
Videostudio X7 (Ultimate) - Audio cuts out
Hi, me again.
When I try to edit a video, the audio cuts out in a video (Usually 3-5 minutes in) and doesn't come back.
I posted this a month ago and forgot about it, so now I'm just remaking the topic.
The properties are this:
http://imgur.com/fUbpzRw.png
I also thing that this might be to do with running out of RAM or something of the sorts so yeah.
If I'm missing anything then just ask me on this thread.
SuperJimbles
May I add that the audio is just fine when I view it in Windows Movie Maker.
SuperJimbles
bumpSuperJimbles wrote:May I add that the audio is just fine when I view it in Windows Movie Maker.
canuck
You forget about a post made a month ago, you don't answer questions and then you expect an answer within a couple of hours of posting?
I replied to you on the 11 November with no reply till 30 Novlata wrote:Hi
Can you give us some information as above
Did you set your timeline/project to use 60fps editing???
SuperJimbles
Sorry I never replied. I forgot and got really busy ;c
Anyways:
1. Recording = Using ShadowPlay to capture various gameplay.
2. No cameras involved.
3. http://imgur.com/fUbpzRw - Properties
4. Yeah, capturing all teh screens :3 (No I'm just capturing my 1st monitor)
5. Nope, no 60fps. Should I do that?
Anyways:
Yes you should set your project to use 60fps because your video file has been recorded using 60 fps.
Does setting the 60 fps editing help.
Your MP4 properties are quite high, I doubt if Video Studio X7 can replicate those settings.
Are you able to record using either…………..
MPEG-4 Files
24 bits, 1920 x 1080, 30 fps
Frame-based
H.264 High Profile Video: 20000 Kbps, 16:9
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
Or 4K which would give the higher settings.
MPEG-4 Files
24 bits, 3840 x 2160, 59.94 fps
Frame-based
H.264 High Profile Video: 38000 Kbps, 16:9
Finally what are you intending to create, if a video disc then you are best recording using 30fps x 1920 x 1080, first option above.
MPEG-4 Files
Frame-based
MPEG-4 Files
Frame-based
SuperJimbles
Just something to upload to YouTube.
SuperJimbles
What I did is I sed all of this except Hz, and bit.lata wrote:Hi
MPEG-4 Files
Frame-based
MPEG-4 Files
Frame-based
20mbps, 1920x1080, 30FPS
No improvements
