alignment phrases,make change in subs after create pro
vasilis
sound_card: nvidia GTX 2060
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: ASUS G731GV
Corel programs: VS 2020
Post by vasilis »
1)how can aligmnet two phrases If one is over the other ?i wnat to be adjacent to one another(look in attachment)and i can do that can i do it automatically?or manual?
2)also if i saved a project with embeding subs can i make any changes in subs later?or must rebuild another project?i make a movie and i choose arial with 18 size.but it don't like very much when i play in tv.the letters looks small.can i make changes in all subtitlles now?or must make a new project?i want if it is possible to change the size of all texts and the font in all text know but not one by one in timeline if you know what i mean
Re: alignment phrases,make change in subs after create
You have created a new line by pressing “Carriage Return”
1 / Place your curser at the beginning of the second line and press “ Backspace “ on the keyboard
Or
2 / Position the curser at the end of first line, Press “delete” till characters line-up, then press space bar to create a space.
Changing fonts/size
There is an option to Copy and Paste Attributes, this may do what you want, be careful to save a copy of your VSP, the Copy and Paste option may affect the location of your text.
Select a clip in the timeline, right click for Copy Attributes, then select other clips to Paste attributes. Shift + Click will select multiple clips.
Take care as I say it may mess up your positioning?
vasilis
Post by vasilis »
thank you.the answer in first quetsion i don't understant very much(the two lines are by default in external subtitles that i downloaded it.this i want to fix).any tutorial for those you told me exist?
for first question with i must make it manually.is teher any automatic way?
Hi vasilis
Please insert the titles to a new project, save the project.
Locate the VSP on the hard drive, zip the VSP and attach to your forum post.
I will download and view those text boxes.
vasilis
Post by vasilis »
how can copy any changes/i dont understand.if i change one sub how can i do automatically the same changes in all subs in the SAME video?(not in other)
canuck
operating_system: Windows 8.1
Post by canuck »
vasilis wrote:how can copy any changes/i dont understand.if i change one sub how can i do automatically the same changes in all subs in the SAME video?(not in other)
Use a proper subtitle editor if you want to edit an external subtitle file.
Hi vasilis
Download the attachment sub title file.
Add a video to the timeline 46 Seconds or more
Set the timeline text editor to your preferred font.
Open Sub Title editor and Import the Sub Title.srt file.
Follow/read the text from 1 to 7
Sub Titles.zip
(488 Bytes) Downloaded 101 times
vasilis
Post by vasilis »
a further aid;in aegisub tehy told me that perhaps with Ctrl i make something called line break and perhaps i can do that and with VS X7
if you have text on two lines then you have to remove the "line brake"
pressing carriage return will cause the text to go to the second line.
Pressing either delete or backspace will remove the space and display the text on a single line.
You are best doing that in the sub Title editor.
Or open the SRT file in Notepad to edit there.
did you download the Zip file... open the srt to the sub title editor to read the information.
Hi vasilis
I have sent an e-mail to you, please look in your mail box.
vasilis
Post by vasilis »
so can i remove linebreak automatically????and how works pressing carriage/and screenshot or video tutorial?
Hi vasilis
Wow thanks for the sample SRT, that’s big, the video must be at least 1hr 45 min, with 1157 titles.
I don’t read or speak Greek, but can see that some of the Titles are on two lines.
I am sure you wish these to be on a single line.
Your best option is to open the SRT using NotePad, I use one called “EditPadLite 7”
There you can identify the Text along with the timeline locations, this is what line 1152 looks like
1152
01:44:43,840 --> 01:44:47,470
Θα την κάνεις αύριο, Φορντ,
γλυστρώντας πάνω στα σκατά σου.
I assume you wish it to display as :-
1152
Θα την κάνεις αύριο, Φορντ, γλυστρώντας πάνω στα σκατά σου.
How….
Place your curser after
And press “Delete” then press the “Space Bar” to input a space.
As you can see there are thousands of titles to edit, although not all are on two lines.
Good luck with this one.
I think the text has been set on two lines because of the length/number of characters.
Two lines will allow the text to display on screen, a single line may loose the text left and right.
I have attached the SRT so others may view, let me know if that is ok.
1.zip
Sub Title file srt
(34.05 KiB) Downloaded 101 times
vasilis
Post by vasilis »
i know how can i do but i dont want to do manually
You cannot do that automatically, it can only be done manually.
You are best to retain the original two lines, changing to one line may be to long to view on screen.
Then you have to change the Font / Font size to make the text fit, the font size may be to small to read.
Changing the font size would be done in the main timeline, doing that in the Sub Editor would affect every/all text.
What is the problem if you keep the two rows.?
vasilis
Post by vasilis »
thanks.i embed the subtitles in movie.but know i wnat delete them.can i deleteall subs at once from timeline?
