Pro x7 dvd burning
ct valley views
ram: 8 gb
Pro x7 dvd burning
Post by ct valley views »
anyone experiencing problems burning DVDs in W7?
files won't finish and the progress bar doesn't move.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: Pro x7 dvd burning
Post by skier-hughes »
Can you give us more information
Have you got all X7 updates installed
All latest drivers for graphics card, audio card and direct x?
What version of windows?
What format are your source files?
Are you going straight from the timeline to dvd?
Can you save the file as dvd compliant mpeg2 file to your hard drive?
Can you then burn this to a dvd after starting a new project?
Can you make dvd folders or an ISO?
Can these be burned to a dvd?
Do you get any error messages?
What are they?
What file won't finish?
Does the progress bar actually start or does it start and then stop at a point?
What point is this?
ct valley views
ram: 8 gb
SEE ANSWERS BELOW IN BOLD
Have you got all X7 updates installed YES
All latest drivers for graphics card, audio card and direct x? YES
What version of windows? W7
What format are your source files? MPEG-2
Are you going straight from the timeline to dvd? YES AS MPEG2
Can you save the file as dvd compliant mpeg2 file to your hard drive? DON'T KNOW HOW TO
Do you get any error messages? NO
What are they?
What file won't finish? NOT ALL THE TIME. IF BURNING MULTIPLE COPIES-ONLY 1 OR 2 WILL BURN
Does the progress bar actually start or does it start and then stop at a point? START & STOP
What point is this? USUALLY AT 45-50%
canuck
operating_system: Windows 8.1
Post by canuck »
What do you mean by burning multiple copies? How are you doing that? Are burning from folder set or an iso image file? (Best method for multiple copies)
So some burns are successful? That shows that the VS program is working correctly.
What DVD make are you using? Some such as Memorexc, Maxell, store brands are unreliable.
ct valley views
ram: 8 gb
SEE ANSWERS IN BOLD CAPS
What do you mean by burning multiple copies? FIVE COPIES OF THE SAME FILE
How are you doing that? ONE AT A TIME
Are burning from folder set or an iso image file? (Best method for multiple copies) FOLDER
What DVD make are you using? Some such as Memorexc, Maxell, store brands are unreliable. HP
canuck
Post by canuck »
Try using some quality DVDs such as Verbatim or Tayo Yuden.
Have you tried using a different program to burn the folder sets such as ImgBurn?
I assume that the folder sets all play properly using a software video player such as VLC?
ct valley views
ram: 8 gb
Try using some quality DVDs such as Verbatim or Tayo Yuden.HAVE HAD NO PROBLEM WITH HP UNTIL NOW. PROJECTS WILL BURN WITH VS 4
Have you tried using a different program to burn the folder sets such as ImgBurn? NO
I assume that the folder sets all play properly using a software video player such as VLC? YES
canuck
Post by canuck »
So there is nothing wrong with VS program in creating the video if the video plays correctly. You also stated that some burns were fine which means that the software works correctly. So that leaves the media, your burner or some compabitibilty problem between your burner and the media.
ct valley views
ram: 8 gb
That's what I thought-but wanted to ask if any problems with VS7.
Thanks for your help
