save movie to sd card
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
hello.i have create and saved with choosing sd card option a movie to a usb stick.but when the process finished i clik on usb and i see the video saved as 4 parts(i certae an mpg4 hd video with 10GB).why is happened that?when i play in tv the stream will be continius?
canuck
Re: save movie to sd card
To which device are you burning the video: to the SD card or the USB stick. These are two different devices. Is your TV able play from a SD card?
Also, most likely the SD card or the USB stick are formatted to FAT32 which means that no file can be larger then 4GB. Your AVCHD movie is also larger then 4GB. Your list shows it to be about 14GB.
As far as I can see, the 'burn to SD card' option in effect co-opts the AVCHD hybrid disc option, and burns the same only to an SD card. And that is the sort of structure you get in an AVCHD/Blu-Ray disc -- a BDMV main folder, and a STREAM folder which contains the actual video -- which is usually broken down into the types of files you see in yours: 00000, 00001 etc...
In a sense, though, it depends on what you are going to use to play the video from the SD card. I don't burn to an SD card, though I do burn regularly to USB stick drives and USB external hard disks. And I usually use VLC player on this computer. When I open VLC player, I go to Media > Open Folder and point it at the STREAM folder, NOT Media > Open File. With the STREAM Folder option, it will then play the individual files in that folder in sequence i.e. there should be no breaks.
vasilis
so can i ''burn'' to a usb or not with Video studio X7?and how can i do that?there is not any option for usb.i want to play movie from usb to tv and i don't want it broken into parts.i think when saved into parts i can play one by one/i dont want that when i play a movie to tv
Have you tried playing the video that is "in parts" - does it play in parts - or as one video
TRY IT and see.
The greatest way to learn is to experiment for your self
TRY IT and see.
vasilis
from the experience in as can i play it as one?
CAN YOU ???? - - you tell us
test it
test it
I would say No, Although there may be a menu structure the TV will see individual files and play one at a time. Seems to do that via USB Stick, if it were on a BD disc then it would play all.
At least that’s what happens on my setup, although I play via the DVD / BD Player., but TV sets can be different?
I would format the USB drive to use NTFS rather than Fat 32.
Then you can add the video as one 14 Gb file.
Depending on the files extension, it may or may not play. But that’s a function of your TV
If you cannot play MTS files try re-naming to use MPG
I cannot comment on SD cards as my TV does not have that facility.
vasilis
thanks lata .You are very helpful ,so if i convert my usb to ntfs should saved as ''one'' video?also can i burn to usb with VS X7?
canuck
vasilis wrote:thanks lata .You are very helpful ,so if i convert my usb to ntfs should saved as ''one'' video?also can i burn to usb with VS X7?
Why don't you just test it instead of asking the same question over and over again.
Hi vasilis
First try playing the files from your usb stick.
When you created the files I assume you used Share – Disc – Avchd. This opens the burner module (authoring module) you created a menu then create Avchd Folder.
You will be best to create a video file first.
Share – Avchd option. Or Same as First Clip.
If you tell us the properties of your original video files we can advise on the best option.
I assume your video files have been recorded using a AVCHD Camcorder.
Right click one of your files and choose properties, what are they?
You can create an image of that window and attach to your post.
vasilis
i have a movie with downlaoding with m torrent.and i choose share with sd card.when i choose ''disk'' it recognised only my optical drive
canuck
If that movie is a commercial movie you downloaded using a torrent then what you are doing is considered pirating and is illegal.
As I said above, I think that the burn to SD option itself chooses the AVCHD hybrid disc format for its output, even though being burnt to an SD card -- and that is regardless of the original format of the project. But I have never used the option except to experiment with it in this case. But I wonder if anyone else has found the same thing?
Vasilis: I regularly create a single AVCHD file from my projects. I don't use Video Studio put it on a USB stick drive or USB external hard disc. I simply use Windows and transfer it like any other file -- though of course if the file is larger than 4 GB, the drive has to be in NTFS format in order not to break up the file.
Next, neither of my HDTVs will play video direct from either an SD card or USB drive. But I have Blu-Ray players connected to both of them via HDMI. And I just plug the USB drive into the Blu-Ray player and play it on the HDTV from there. It works extremely well. The only downside of this method is that you don't have a menu.
vasilis
thank you ken.so is prefer to create an AVCHD single file/and how can i do that exaclty?
