How to make a collage from 6 images in workspace
Re: How to make a collage from 6 images in workspace
Thanks for swift reply. One of my straight arrow icons moves the photo. The other one changes the size. If the rectangle is showing, you can not deform the picture from a rectangle but you are not locked in the original aspect ratio.If I hold the shift key the small rectangle becomes a trapezoid and the outline or shape of the photo can be deformed. Holding the alt key while using the double arrow icon will allow a different type of trapezoid and the photo can be "stretched". Holding the control key brings up the rectangle again but no lock. If your double arrow icon does not have the rectangle then maybe I have a bug where the default brings up the function as would holding the alt key.
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
I am not at my PC at the moment and it does have have PSPro installed so I can't check it out.By the way, I have X5, don't now if that is different to you- that may affect things.Are you dragging from the corner node?Are you actually working with the intended tool-from memory, there is a drop down arrow on the pick/move tool which changes what you are using between the two.
