Hallo, i would like to know if is possible to install the two versions of AS on the same computer and folder mainly to use 32 bit plugins.
32 & 64 bit
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: 32 & 64 bit
You can not share the plugin directory, so you end up with two user directories....
cheers
afx
cheers
afx
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Re: 32 & 64 bit
32-bit Plugins go into "Plugins"
and
64-bit Plugins into "Plugins (64-bit)"
and
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
afx
- System_Drive: N/A
Re: 32 & 64 bit
Since when?Tadjio wrote:32-bit Plugins go into "Plugins"
and
Looks like I should play withe the 64bit version more, I missed that change.
cheers
afx
Tadjio
- sound_card: Sound
Re: 32 & 64 bit
Since I started using 64-bit plugins. For example I have zPerspector in both.afx wrote:Since when?Tadjio wrote:32-bit Plugins go into "Plugins"
and
Tadjio
