Images NEF are slightly green in Aftershot 2 Pro
jbgl
- motherboard: Gigabyte Z87-D3HP
- processor: Intel Core i7 4770
- Video Card: GeForce GTX 770
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: AOC 2236 Full HD
Good Morning !!!
Can anyone help me?
I started using Aftershot Pro 2 and every NEF (RAW) images I open it, are slightly green.
What am I doing wrong?
Examples comparing Aftershot with Photoshop.
Note: In photoshop it does not.
Thank you!
Can anyone help me?
Thank you!
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: Images NEF are slightly green in Aftershot 2 Pro
yes I have these problems too - many (all) pictures are to greenish - I have a preset (nuance plugin) correcting it - but this is a problem of ASP/bibble ... unfortunately the do not correct it ...
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
afx
- System_Drive: N/A
- Video Card: FirePro 4900
I very much doubt it is every NEF, but only the NEFs from a specific camera.jbgl wrote:every NEF (RAW)
I don't have that effect on the D70, D300, D700, D800, D4.
So which body and what NEF setup (12/14bit, compression)?
cheers
afx
jbgl
My NEF images were taken by a NIKON D5300.
NOTE: I did all the updates AfterShot but the problem persists.
Tks!
Tks!
jbgl
Forgot to mention that the setting of NEF image is 14bits.
Tks
Tks
jbgl
afx wrote:I very much doubt it is every NEF, but only the NEFs from a specific camera.jbgl wrote:every NEF (RAW)
cheers
afx
I use a NIKON D5300 NEF configuration 14bits.
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
gareth
- motherboard: Acer Aspire TC-605
- ram: 12Gb
- Video Card: NVIDIA GeForce GTX 745
- Hard_Drive_Capacity: a few TB
- Monitor/Display Make & Model: AOC 2369M sRGB
I was about to report a similar issue with my trial of ASP2 and my OLY M5.
RAW image under warm tungsten light of silver coin on white paper appears warm as expected with temperature about 2200 -- then choose incandescent or click white on paper and a green cast appears.
However, on further checking, i find ASP1 behaves the same. Were the images above also under tungsten light?
Cap-1 gives a white image from same RAW.
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
Vernie
- System_Drive: N/A
- motherboard: Asus X550DP
- processor: AMD A8
- ram: 4GB
- Video Card: AMD Radeon HD8670M
- Hard_Drive_Capacity: 180GB
- Monitor/Display Make & Model: 15" Asus X550DP
Confirmed, this problem also exist in Aftershot 2 Pro version 2.1.1.9 x64 on Linux (Ubuntu 14.04/Linux Mint 17.1). Any Nikon D5300 NEF 12bit and 14bit photographs are rendered towards a slightly green color.
update:
Also tested the Aftershot 2 Pro version 2.1.1.9 32bit version, same problem occured (Ubuntu 14.04/Linux Mint 17.1).
update:
Tommy_CZ
- System_Drive: N/A
- motherboard: -----
- processor: AMD 6-core
- Video Card: NVIDIA+Intel
- sound_card: audigy Rx
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: sRGB calibrated
- Corel programs: AftershotPro 2
THey will repair it in BRAND NEW fantastic version 3.0.0.120 for only $50! If you are owner of previous, obsolete version 2.1, then it will cost only $48! Wow, what a deal! With brand-new features like FINALLY working OpenCL for really ALL mainstream GPUs, inluding so exotic types like NVIDIA GT 630 etc.... I am so amazed! wow!
where is the version 3.0.0.120, Now os 2015Tommy_CZ wrote:THey will repair it in BRAND NEW fantastic version 3.0.0.120 for only $50! If you are owner of previous, obsolete version 2.1, then it will cost only $48! Wow, what a deal! With brand-new features like FINALLY working OpenCL for really ALL mainstream GPUs, inluding so exotic types like NVIDIA GT 630 etc.... I am so amazed! wow!
