I've been searching for a script that will divide any image exactly into quarters and save each of those new files. So far without success, even on Suz Shook's excellent site.
Can anyone help me locate one please, or get me started on making one myself?
Alternatively, is there a really simple method to do this, in PSP 8, which I might then be able to copy with an external macro? My approach so far has been too reliant on careful positioning of the horizontal and vertical guideline to be amenable to a macro.
Terry, East Grinstead, UK
Didvide image into quarters - and save each?
terrypin
- motherboard: Asus Z170 Pro 4
- processor: Intel Core i7 6700K 4.0GHz
- ram: 32 GB
- Video Card: None - uses built-in graphics
- sound_card: HD onboard sound card
- Hard_Drive_Capacity: 4.256 TB
- Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
- Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Using PSP 8 & PSP 2018 under Win 10
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Didvide image into quarters - and save each?
Do you have the Image Slicer command? I'm not sure when this was introduced.
Image Slicer can be found somewhere around File -> Export in later versions.
This dialog is meant to save out files for the web. It includes a "Grid" tool. When you click on the image using the grid tool it asks how many rows an columns. Enter 2 for both rows and columns to get 4 equal pieces. Then continue to use the dialog to save out the result. By default it tries to save as a GIF so you'll want to save out as a PNG orJPEG instead.
If you want a script, that should be fairly easy. Just need to create a script that creates a selection around each 1/4th of the image and copies it to a new image. Can't promise good results with this. Can't even promise it'll work in PSP8.
Code: Select all
from JascApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u''
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {})
rows = 2
columns = 2
CurrentDoc = App.TargetDocument
w = CurrentDoc.Width
h = CurrentDoc.Height
cw = w/columns
ch = h/rows
for y in range(0,rows):
for x in range(0,columns):
top = y*ch
left = x*cw
# SelectNone
App.Do( Environment, 'SelectNone', {}, CurrentDoc)
# ModifySelection
App.Do( Environment, 'ModifySelection', {
'Selection': ((left,top), left+cw, top+ch),
'Type': App.Constants.SelectionModifyType.Custom, 'GeneralSettings':{'ExecutionMode': App.Constants.ExecutionMode.Silent}}, CurrentDoc)
# Copy
App.Do( Environment, 'Copy', {}, CurrentDoc)
# PasteGraphicAsNewImage
App.Do( Environment, 'PasteGraphicAsNewImage')
terrypin
- ram: 32 GB
Yes! Thanks a bunch, that tool does exist and when I can get the hang of it I reckon it will be exactly what I need.
My immediate problem is that despite selecting PNG instead of the default GIF, only the top left slice gets saved as PNG, the other three as GIF. It's probably down to me, as I'm a bit unclear about the rather complex dialog. Presumably I can't simplify it by removing all references to HTML and web pages? I want to save merely the image slices, yet it seems I get this only as a by-product of saving an HTM.
When I better understand the tool itself, I'll study and try your script. Very kind of you to take the trouble.
terrypin
- ram: 32 GB
Image Slicer
Happily, I eventually got that saving 4 PNGs.
Your script
Works a treat thanks!
I did have a rather puzzling difficulty. After using Select All on your script in the forum post, all looked well. But when I pasted it into my text editor, it added four spaces to the left of all lines. So running it gave a syntax error. Pasting to Notepad added the same unwanted spaces. But after deleting those it worked OK. I'm assuming you intended that a selection needs to be made (ALL in my case) before running it?
Thanks again for all your help - much appreciated.
Your script
