Install problem ASP2 ( Error:cannot satisfy dependencies)
Mikro
operating_system: Linux
Hard_Drive_Capacity: Melbourne
Post by Mikro »
I get this dependency error when I try to run the Deb install of Aftershot Pro2 (.AfterShot2x64)
I have Linux Mint 17 on a Toshiba 64 bit Intel 2.4GHz laptop.
It ran fine on Mint 16 but not now..
Need help..Thank you,
Mikro
pgman
System_Drive: N/A
Re: Install problem ASP2 ( Error:cannot satisfy dependencies
Post by pgman »
I had the same problem, then in a "stroke of genius" I tried to install it with the "Ubuntu Software Centre" and it worked. There must be an equivalent in Mint or after the failure run:
Code: Select all
sudo apt-get -f install
That will fix all the errors
/Syv
Mikro
Post by Mikro »
pgman wrote:I had the same problem, then in a "stroke of genius" I tried to install it with the "Ubuntu Software Centre" and it worked. There must be an equivalent in Mint or after the failure run:
Code: Select all
/Syv
Code: Select all
mikro@mikro-Toshiba-Satellite:~ > sudo apt-get -f install
[sudo] password for mikro:
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 35 not upgraded.
This is what came up after apt-get -f install
It does't show up in software manager..
pgman
System_Drive: N/A
Post by pgman »
I used the software centre on my desktop and the apt-get on my laptop. But I'm using xUbuntu 14.04.
/Syv
