Best possible quality
hyawatha15
What are the settings for the BEST possible video capture for StudioVideo9? Im capturing video from a xbox, and the quality isnt that great, how can I make it better?
heinz-oz
hyawatha15
jchunter
I'm going to assume that this Xbox (manufacturer?, model?) converts analog video to digital and stores it via (what kind?) of connection into your computer. What are the properties that you set when you captured using this Xbox?
When you say the quality is "not great" what VS display are you looking at? (e.g., capture preview, Edit mode instant preview, etc)
John
John
THoff
Nope, that's a Microsoft XBox gaming console -- he's trying to record his gameplay.
Regarding the bundling, Videostudio came bundled with the VideoMPX, not the other way around. Otherwise I'd demand a VideoMPX box from Ulead, 'cause I didn't get mine...
According to the specs for the VideoMPX, you need a USB 2.0 connection to record full quality video (makes sense). If the box is plugged into a USB 1.1 connection instead, you're limited to recording MPEG1 at 352x240 or 352x288, depending on whether you are in NTSC or PAL land.
hyawatha15
THoff
According to specs for the VideoMPX, it can capture at Full D1 resolution, albeit at somewhat odd framerates if the specs are accurate. NTSC should be 29.97fps, not 30fps, and PAL should be 25fps, not 24fps.
So basically, you should be able to capture DVD quality video with this thing, provided you don't use it's built-in MPEG encoder (it only handles MPEG1 at VCD resolution) and capture in AVI format with a lossless or high-quality codec.
hyawatha15
