Aftershot Pro 2 v2.0.1.40 upgrade problem 64 bit Ubuntu
Bugs & Suggestions
sventhepaddler
operating_system: Linux
System_Drive: N/A
Post by sventhepaddler »
I am attempting to upgrade my Aftershot Pro 2 from 2.0.3.25 to 2.0.1.40. My system is 64 bit Ubuntu. I download the 64 bit Debian file and install it using "sudo dpkg -i AfterShotPro2_amd64_2.1.0.40.deb " There are no errors with the install. However, rather than the 2.0.1.40 version of Aftershot Pro 2, I have 2.0.1.40 Aftershot 2. Did they put up the wrong .deb file?
-sven
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Aftershot Pro 2 v2.0.1.40 upgrade problem 64 bit Ubuntu
Post by afx »
Check the splash screen ;-)
cheers
afx
sventhepaddler
System_Drive: N/A
Well after I launch it, the splash screen says v2.0.3.25 and there is a pop up that says "You have version: 2.0.3.25 There is a newer version available. Get Version 2.1.0.40 here More details".
I go to the link provided and download the file http://dwnld.aftershotpro.com/updates/v ... _amd64.deb. I install the .deb file and now I have a new command, AfterShot2X64. When I launch that, it is version 2.1.0.40 but it is AfterShot2, not AfterShot2Pro. Plus it says my trial has expired.
I'm not sure what I'm missing here...
Zrubi
System_Drive: N/A
ram: 4GB
Video Card: nVidia GTS 250
Monitor/Display Make & Model: DELL U2311H
Post by Zrubi »
