Drag, yes--but drop?
oldmaven
motherboard: Dell Inc. 0TP412 A02
processor: 2.67 gigahertz Intel Core2 Quad Q6700
Video Card: NVIDIA Quadro NVS 290
sound_card: SoundMAX Integrated Digital HD Audio
Hard_Drive_Capacity: 2000 GB
Monitor/Display Make & Model: Samsung; ViewSonic
Corel programs: PSP X7 Ultimate; Aftershot 2 P
Post by oldmaven »
For a long time -- even in Aftershot Pro 1, drag and drop have not worked consistently. Sometimes, dragging from the central pane to folder moves the files (which is as it should be), but about 40% of the time it just copies them.
And sometimes, even when it does move the files, the thumbnails remain until I refresh the screen.
How do I fix these problems?
maggus
operating_system: Linux
System_Drive: B
Re: Drag, yes--but drop?
Post by maggus »
that's exactly the reason why I do not update to new version by spending more money .... the Corels are not abel to fix major UI issues!
I observe that you can not move pictures to a different folder ... solution: select another folder, then return to you source folder and select the pictures to be moved again .... then it works ( at least on my machine ).
Another major UI issue is that sometimes DEL/INS/Rename operates on the wrong ( previously selected) set of images .... really not nice.
chears and good luck
Markus
OpenSuse 11.4 (32bit)
Dell U2410
