I downloaded AfterShot2 for Linux and I like it a lot. I want to buy now that there is an offer for the 27th of Oct.
However there is something that puzzles me.
I tried some RAW images (my camera is a Samsung NX300) and I noticed that White Balance and Highlights are locked (I can't set them). Is this because of the trial version or something else?
Thanks for your time,
Chris
locked white balance?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: locked white balance?
They should not be locked on supported raw files, that sounds rather strange.
Can you make a file available?
cheers
afx
cheers
afx
xpanta
- motherboard: Gigabyte GA EP45
OK. Please, bear in mind that my UBUNTU 14.04 does not support SRW files (RAW files from my Samsung) so I convert them to Tiff using ufraw with this command:afx wrote:They should not be locked on supported raw files, that sounds rather strange.
cheers
afx
ufraw-batch --wb=camera --exposure=auto --out-type=tiff --out-path=. \
Please, take a look at this photo, yourself.
https://dl.dropboxusercontent.com/u/242 ... M_2244.tif
afx
- System_Drive: N/A
Please...
You wrote you have an issue with RAW files.
This is a TIFF.
That explains it.
On rendered files, AS only supports click white WB.
cheers
afx
This is a TIFF.
That explains it.
cheers
afx
xpanta
Thanks, I thought that tiff and RAW were the same.afx wrote:Please...
This is a TIFF.
That explains it.
cheers
afx
How can convert SRW to some format that both AS and Nautilus understand?
Shrievelty
I have the same problem: the White balance freezes when I am adjusting my CR2 files (from Canon 350D).
To be more precise: when I click 'Click white' the eyedropper sometimes works once, then the tool freezes and the photo will not change in balance when I click elsewhere in the image. Sometimes the tool does not even work once.
However, Click White works correctly with the CR2 files from my Canon S110.
afx
- System_Drive: N/A
Most raw files actually use the TIFF format as a container, but then the contents is totally different.xpanta wrote:Thanks, I thought that tiff and RAW were the same.
Well, TIFF is your only option right now and the only things that will not work in AS on TIFFs is white balance and highlight recovery.How can convert SRW to some format that both AS and Nautilus understand?
cheers
afx
xpanta
Thank you very much.afx wrote:Most raw files actually use the TIFF format as a container, but then the contents is totally different.xpanta wrote:Thanks, I thought that tiff and RAW were the same.Well, TIFF is your only option right now and the only things that will not work in AS on TIFFs is white balance and highlight recovery.How can convert SRW to some format that both AS and Nautilus understand?
cheers
afx
I tried openning a .SRW file from my camera (Samsung NX300) but AS does not display it (I didn't convert it to tiff). I guess this format is not supported, or am I doing something wrong?
This is my SRW file: https://dl.dropboxusercontent.com/u/242 ... M_2239.SRW
afx
- System_Drive: N/A
