Opening image in adjust workspace
UnlikelyMoniker
Post by UnlikelyMoniker »
When I click on the Adjust tab while working on an image in the edit workspace, the Adjust workspace opens OK but the active image isn't displayed. I have to use the file browser to locate it and re-open it. I understood that PSP should automatically display the active image in the selected workspace each time the user switches between the Edit, Adjust and Manage tabs. Am I missing something?
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Opening image in adjust workspace
Post by trueblue »
You don't say which version of PSP you are working with.
I have an image open in PSP X7, click Adjust and the same image in Edit opens in Adjust just fine.
Can you explain a little more what exactly you are doing?
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
UnlikelyMoniker
trublue,
I'm on X6. I open an image in the Edit workspace. I click Adjust. The Adjust workspace opens showing another image (the last one I worked on in Adjust). I click on Edit and the image currently in Adjust opens in Edit. The image that I opened in Step One is gone - as in completely gone from PSP, it's not open in another Edit tab or minimised.
The behaviour is consistent whether I open images into Edit via the File-Open option, File-New, drag an image from Windows Explorer or right click on a file in explorer and choose PSP from the Open with... context menu.
The only exception to this is if I browse to the image's folder with PSP's Navigator and then open it by clicking on a thumbnail in the PSP Organiser. On my PC, PSP will only toggle images between Edit and Adjust if they're in the folder that's currently open in Organiser.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
For whatever reason Corel believes you should work from left to right (Manage -> Adjust -> Edit) and not vice versa. I'm not saying I agree with this reasoning; just stating that's what it is. Personally I work strictly in the Edit workspace.
I did test X6 and X7 and both behave the same way for me. Here's what I found.
I opened an image in Edit and then switched to the Adjust tab. The following happened:
1. If no changes were made to the image the image in Edit was automatically closed
2. If changes were made to the image I was given the option to save or not prior to the image being automatically closed
3. A different image appeared in the Adjust tab. It happens to be the first picture in My Pictures folder.
4. When I switched back to the Edit tab the picture from the Adjust tab was retained.
UnlikelyMoniker
Thanks kathy_9. Glad to know it's not just me.
I work in the Edit tab 95% of the time so I guess I'll carry on ignoring the Adjust tab!
