Segmented Circle
billbogan052
motherboard: Dell M6700
processor: Intel i7-3740QM 2.70 GHz
ram: 16 GB
Video Card: nVidia Quadro K3000M
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell M6700
Segmented Circle
Post by billbogan052 »
Hello,
Is there a good workflow for creating a circle that is divided into multiple colors? (Not a pie, but a doughnut)
Using cartesian coordinates, think in these terms...
0-89 degrees = BLUE
90-179 degrees = YELLOW
180-269 degrees = GREEN
260-359 degrees = RED
I have a workflow now, but it is cumbersome and involves other software to generate the circles. If there is a way to do this, then I can also look at varying the circle size and creating a stepped, segmented circle.
Thanks,
Bill
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Segmented Circle
Post by LeviFiction »
You mean something like this?
My process was not fast. But it's kind of simple.
1) Create a new gradient
2) Setup the stops as follows:
Stop 1: Blue Position 0
Stop 2: Blue Position 25
Stop 3: Yellow Position 25
Stop 4: Yellow Position 50
Stop 5: Green Position 50
Stop 6: Green Position 75
Stop 7: Red Position 75
Stop 8: Red Position 100
3) Save Gradient
4) Use Radial Style gradient, center point 50h 50v
5) Set gradient as background/fill color
6) Drag out Ellipse
7) Convert Ellipse to Path
8 ) Using the pen tool select all 4 nodes of the ellipse, then use the "Duplicate & Offset" function with the offset at 0X and 0Y. This makes sure that the new contour is in the same place.
9) Use the "Contraction" option, with the X and Y at equal amounts. And shrink it to the size of the hole you want.
10) With the inner circle still selected go to Object -> Edit -> Reverse contour This will cut a hole in the ellipse
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
I would have gone with a different flow:
- on a square image, select a custom selection that will be the top left quarter of the image, flood fill with red
- Selection - Edit selection, Mirror horizontally, Selection - Edit selection, Flood fill with Blue
- Selection - Edit selection, Mirror vertically, Selection - Edit selection, Flood fill with Yellow
- Selection - Edit selection, Mirror horizontally, Selection - Edit selection, Flood fill with Green
- deselect
Place guides, vertically and horizontally, and have the Snap to guide checked.
Select a circle as large as the outer edge of your donut.
With the right-click, move the selection toward the center where it will snap
Invert selection (Ctrl-Shift-i) and delete.
Invert again
Contract selection by the amount you want the thickness of the donut and delete
You should have a donut left with the four colors
Cassel
https://scrapbookcampus.com
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Then convert it to a picture tube and you can get "varying the circle size and creating a stepped, segmented circle."
