Aftershot Pro 2.1.0.40 & Sony RX100 II
Bugs & Suggestions
The Doc
Post by The Doc »
There seems to be bug with version 2.1.0.40 when converting Sony RX100 ver II images. About 5% of the time there is line mostly across the middle of the image, due to a defective conversion. Anyone else seeing this?
The attached file has it in two places, look at the trees.
regards
Michael
Processors: 12
CPU Threads: 12
I/O Threads: 1
B. In-flight: 4
RAM: 12286 MB
SIMD Version: SSE2
Build Mode: Release
Proc. speed: 3.3 GHz
OS Name: Microsoft Windows 7 Service Pack 1
OS Version: 6.1 (Build 7601)
System arch: x64
Memory used: 76%
The Doc
Re: Aftershot Pro 2.1.0.40 & Sony RX100 II
Post by The Doc »
I wonder whether it might be this bug: http://forum.corel.com/EN/viewtopic.php?f=90&t=54857
The Doc
Post by The Doc »
No as it still occurs, even if I remove sharpening in Aftershot.
The Doc
Post by The Doc »
Sharpening on, full size jpg, no problems.
No problem with no sharpening and full size as well.
So issue seems to be about resizing.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
It is the combination of resize and USM in the queue.
Development has already been notified.
cheers
afx
The Doc
Post by The Doc »
Thanks.
kd5bwt
processor: Intel I7-2600k not overclocked
Video Card: GeForce GTX 460 SE
Hard_Drive_Capacity: plenty
Monitor/Display Make & Model: HP ZR24w
Post by kd5bwt »
I just went through the trouble of diagnosing and writing this up as well.
Banding traced down to sharpening in a batch, same camera, visible here: http://test.diff.net/3private/asp64_lin ... 09_std.jpg
http://test.diff.net/3private/asp64_linux_bug_report_2/
Between this and the deadlock I reported on Oct 3 (http://forum.corel.com/EN/viewtopic.php?f=94&t=54763), getting kind of frustrated.
-Peter
afx
System_Drive: N/A
Post by afx »
That is not banding, it is a tile artifact. Should be fixed in the next release.
Workaround: http://forum.corel.com/EN/viewtopic.php?f=90&t=54857
cheers
afx
