The R G B L readings on the status bar do not correspond with those that I see in other eyedropper tools.
1. What do they mean?
2. How can I see normal readings? So that, for example a patch which is L 50 in Lab appears as L 50 on the status bar?
Status - R G B L readings - what do they mean?
Shrievelty
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Status - R G B L readings - what do they mean?
L is luminance, not Lab, if it where lab it would be "a b L" and not "R G B L".
Lab readings are not normal. RGB readings are. Especially in a program that does not provide a Lab working space.
cheers
afx
cheers
afx
Shrievelty
Many thanks for your reply, afx?
What puzzles me is this:
In the free eyedropper reader, Pixie, I get the same readings as in Photoshop, but different readings for the same patch in CAS.
For example:
Pixie G 110, Photoshop G 110, CorelAfterShot G 177
Pixie G 181, Photoshop G 181, CorelAfterShot G 219
What is the reason for this difference?
For example:
afx
- System_Drive: N/A
It all depends on the working space. AS uses linear Prophoto, you cant' compare that to an sRGB or Adobe RGB readout.
If you click on the color rectangle next to the readout, you can toggle linear/gamma, that also influences it.
cheers
afx
cheers
afx
Shrievelty
Thanks again, afk.
That little square did wonders. I had indeed got it set up as sRGB. However after I took your hint and selected 'linear' the readings matched those from Pixie and Photoshop.
