ASP 2.1.0.40 Hangs When Deleting Files
Bugs & Suggestions
dsigman
motherboard: ASUS A78M-A
processor: AMD A8 6600K
ram: 8 GB
Video Card: ASUS R7 250X
sound_card: AMD High Definition
Hard_Drive_Capacity: 1 TB
Post by dsigman »
Just installed ASP 2.1.0.40 and found that they still have not fixed the bug that makes deleting versions very slow.
lacey
motherboard: ASUSTeK Computer Inc. G73Jw 1.0
processor: 1.73 gigahertz Intel Core i7 Q 740
Video Card: NVIDIA GeForce GTX 460M
Hard_Drive_Capacity: 1256 GB
Monitor/Display Make & Model: Hanns.G HSD173PUW1 - 17.8"vis
Re: ASP 2.1.0.40 Hangs When Deleting Files
Post by lacey »
Installed new ASP v2.1.1.9
[UPDATE] :: The problem stopped after I changed the name of the folder in which I was working. It contained an apostrophe (" ' "), which can sometimes cause problems when used in paths or filenames. I suspect this may have been the cause. Works fine now.
A second problem also corrected itself after doing this. Newly created versions were not being automatically stacked, but would appear at the bottom of the set of files within that folder instead. After removing the apostrophe, versions stacked correctly.
[ORIGINAL COMMENT] :: Still a problem.
ASP crashes when I delete versions. In restarting ASP, though, the versions have been removed.
