Just upgraded to 2.1.0.40 pro
pgman
operating_system: Linux
System_Drive: N/A
Post by pgman »
I just "upgraded". According to the docs, Linux needs first to uninstall. Did that, but kept my .AfterShotPro folder.
* I had to reenter my name/serial
* I lost my customizations like keyboard and new numbering schemes (I thought that they were stored in the .AftershotPro folder)
Did I miss a step?
BTW,
1. It does an almost decent job on Fuji-X files
2. Will there be soon another update to support the coming Canon 7DMk2?
Syv
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Just upgraded to 2.1.0.40 pro
Post by afx »
pgman wrote:* I lost my customizations like keyboard and new numbering schemes (I thought that they were stored in the .AftershotPro folder)
No idea why, but yes, that is broken...
cheers
afx
Kneops
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
I'm happy with the update :), good to see that work has been done on the Fuji camera's, although I have the same problem: my custom iptc meta settings and my custom tag settings are gone :(
I do have a backup of the old .AfterShotPro folder, but I can't find what file I should copy back to the new installation.
afx
System_Drive: N/A
Post by afx »
Kneops wrote:I do have a backup of the old .AfterShotPro folder, but I can't find what file I should copy back to the new installation.
hotkeys.xml
locale/en/keywords.xml
locale/en/metaDataSets.xml
locale/en/keywordSets.xml
where the ones I copied if I remember correctly.
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Thanks afx! I didn't look in the locale folders, thinking those were for the user interface.
I copied the ones out of my /nl/ folders ;)
Could you also tell me where to find the HDR?
I'm using the 64 bit Linux verrsion (deb).
afx
System_Drive: N/A
Post by afx »
Kneops wrote:Could you also tell me where to find the HDR?
Select the images, right click ...
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Zrubi
System_Drive: N/A
ram: 4GB
Video Card: nVidia GTS 250
Monitor/Display Make & Model: DELL U2311H
Post by Zrubi »
pgman wrote: I just "upgraded". According to the docs, Linux needs first to uninstall. Did that, but kept my .AfterShotPro folder.
Did I miss a step?
If you want to install this new version on Linux - without any pain - do these steps BEFORE you attempt to start the newly installed package.
Code: Select all
cd ~/
# Link the default Library folder:
ln -s AfterShotPro AfterShot
#  Copy the config diretory
cp -a .AfterShotPro .AfterShot
# Copy the config file
cp -a .config/Corel/AfterShot\ Pro.conf .config/Corel/AfterShot\ 2.conf
Wiev my full post about this mess:
http://forum.corel.com/EN/viewtopic.php ... 06#p297006
