AfterShotPro 2.1.0.40 ?
gpe
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8P67 LE
processor: i5-2500k
ram: 16 GB
Video Card: Nvidia GTX550Ti
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Dell U2410
Corel programs: AfterShot Pro 2
Re: AfterShotPro 2.1.0.40 ?
Post by gpe »
afx wrote:If you install it, it will tell you it is the pro version.
cheers
afx
Ok but can I point to my old directories. By default it wants to create new ones ?
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
gpe wrote:Ok but can I point to my old directories. By default it wants to create new ones ?
Sure,
but make sure you save the old ones. It insists on overwriting some of the user stuff (metadata sets, some keyboard definitions, raw defaults).
cheers
afx
gpe
System_Drive: N/A
processor: i5-2500k
ram: 16 GB
Post by gpe »
I've installed it but there are some bugs:
- the about dialog box isn't displayed,
- in 64 bits version there is none icon in the menus
afx
System_Drive: N/A
Post by afx »
gpe wrote:I've installed it but there are some bugs:
It helps to mention the OS when noting something like this.
cheers
afx
gpe
System_Drive: N/A
processor: i5-2500k
ram: 16 GB
Post by gpe »
Oh yes sorry: I'am under debian Jessie 64 bits.
afx
System_Drive: N/A
Post by afx »
On my Ubuntu box I can see that the icons are missing in the 64bit version, the splash screen/about box did not show up on first start, but since then it was always there.
cheers
afx
madsec
System_Drive: N/A
motherboard: Macbook 5.1 - Intel based
processor: Core 2 Duo 2.0 GHz
ram: 8 GB
Video Card: Nvidia Geforce 9400 Go
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: Macbook 5.1 - 13 inch
Post by madsec »
Arnfinn wrote:I feel a bit degraded when there's no Pro in the name anywhere in the application work area, unless I open the splash screen under Help > About Aftershot 2...
That is by far the only place it says I'm running the Pro version. Everywhere else, it's just AfterShot 2 :?
Yes, I do have HDR and everything else, but please Corel; If I purchase the PRO version, I would certainly want to have it appear that way, and not be left with the low down feeling of the stripped down entry level version when working with my images...
Don't worry, the standard AfterShot 2 will not be released for Linux, according to this pdf I found on the Corel website, so we use the Pro version on Linux for sure :)
Link to pdf: http://img.aftershotpro.com/en/pdf/afte ... arison.pdf
fukapon
operating_system: Windows 8.1
Post by fukapon »
I tried 2.1.0.40 for Windows 64bit with Pentax 645Z PEF. Unfortunately, it has a bug drawing black and white bars on left and right sides.
I failed to attach a sample pic so I link to Flickr page of the pic. https://www.flickr.com/photos/fukapon/15436839880/
If you want the RAW, get it from here. https://www.dropbox.com/sh/al3ibh3dse15 ... 1oYzAupvBa
Zrubi
System_Drive: N/A
ram: 4GB
Video Card: nVidia GTS 250
Monitor/Display Make & Model: DELL U2311H
Post by Zrubi »
afx wrote:They messed up the names ;-)
They made a huge mess around this product :)
If someone wonder there is NO 'non pro' version. It was before Corel bought the Bibble but they just adopted (renamed) the 'Bibble 5 Pro' to 'Corel AfterShot Pro'.
  • To star making this mess they just renmed 'Bibble 5 Pro' to 'AfterShot Pro' - With this move the just broke ALL the contributed plugins.
  • To make it more messy they just abadoned the 'old' AftershotPro after the version 1.2.0.7
  • Then they released a 'new' AfterShotPro2 - with a fantastic new feature: 64bit and as a side effect they broke ALL of the plugins AGAIN!
  • Now (2.1.0.40) they just started to rename the whole thing to 'AfterShot 2' - Whit this move now they broke all the user settings - because the 'new' program using new config files and directories.
BRAVO COREL!
If you want to install this new version on Linux - without any pain - do these steps BEFORE you attempt to start the newly installed package.
Code: Select all
cd ~/
# Link the default Library folder:
ln -s AfterShotPro AfterShot
#  Copy the config diretory
cp -a .AfterShotPro .AfterShot
# Copy the config file
cp -a .config/Corel/AfterShot\ Pro.conf .config/Corel/AfterShot\ 2.conf
And just have a look to this naming mess - to see how this renaming attempt failed:
We get the the binary: - Notice the directory name as well ;)
/opt/AfterShot2/bin/AfterShotPro
We got a shell script - calling the binary mentioned above:
/usr/bin/AfterShot2
and we got some nice config directories and files with f*cking spaces included:
.AfterShot
.config/Corel/AfterShot 2.conf
to see more renaming fail:
strings /opt/AfterShot2/bin/AfterShotPro |grep bibble
Oh, and not forgot the fact that they CAN'T make a proper .rpm package with VERSION numbers. All the f*ked packages are installed with the same version number:
Code: Select all
Arch          : i386
Epoch       : 174
Version     : 2.0
Release    : 0.0
Thank You, Corel.
Arnfinn
motherboard: ASUSTeK Computer INC. SABERTOOTH X58 Rev 1.xx
processor: Intel Core i7 CPU 960 3.20GHz 3.20GHz
ram: 12 GB
Video Card: NVIDIA GeForce GTX 670
sound_card: High Definition Audio Device [5x]
Hard_Drive_Capacity: 12 TB
Monitor/Display Make & Model: BenQ G2400W 24,0" + Acer X203H 19,9"
Corel programs: ASP
Post by Arnfinn »
madsec wrote:Don't worry, the standard AfterShot 2 will not be released for Linux, according to this pdf I found on the Corel website, so we use the Pro version on Linux for sure :)
Relax, I don't have Loonix... :mrgreen:
Long time AfterShot Pro & Bibble user...
http://creativewithlight.com/
