AfterShotPro 2.1.0.40 ?
gpe
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8P67 LE
processor: i5-2500k
ram: 16 GB
Video Card: Nvidia GTX550Ti
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Dell U2410
Corel programs: AfterShot Pro 2
Post by gpe »
I've saw at http://www.aftershotpro.com/en/support/updates/#tab=1 that there is an update but when I installed the package on my debian it seems that it's an AfterShot version not an AfterShotPro.
What about it ?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: AfterShotPro 2.1.0.40 ?
Post by afx »
They messed up the names ;-)
No idea what the logic behind this is, but that is also the reason the install instructions for Linux explicitly state to de-install the previous version.
This is the first public version wit X-trans support...
cheers
afx
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Warning to non-English speakers on Mac & Linux
Post by Dutchmm »
If the Italian instructions are representative, the translation process has omitted to mention the need to de-install the previous version. I also checked the French version - no mention; Dutch - no mention. It looks to me as though the warning only appears in the English and German versions. Perhaps there are other omissions in the non-European languages, too?
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
only wrong name or no pro version?
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
afx
System_Drive: N/A
Post by afx »
If you install it, it will tell you it is the pro version.
cheers
afx
hannes_hab
System_Drive: Z
ram: 16 GB
thank you - it worked!
One thing that did change: I have the thumbnails under the picture - with the last version I was able to scroll (only) horizontal (thumbnail size was scaled with a slider on the right side - like it is shown in the help file) - now there are lines and columns and the slider is below the thumbnails.
How to change this ?
regards Hannes
austria
afx
System_Drive: N/A
Post by afx »
Pull down the area to be one line only.
cheers
afx
hannes_hab
System_Drive: Z
ram: 16 GB
I tried that - but this only works if the thumbnails are in a vertical line - not if the line is horizontal.
Also -scaling of landscape and portrait only works with vertical thumbnail-line. This feature was fine for panoramas ...
I am on linux (ubuntu 12.04)
regards Hannes
austria
afx
System_Drive: N/A
Post by afx »
Ouch, I just tried it, silly bug.
I never use thumbs at the bottom as I don't do panos and todays 16:9/16:10 screens are better utilized with a vertical strip for regular size images.
I'll open up a bug report.
cheers
afx
hannes_hab
System_Drive: Z
ram: 16 GB
ok - thank you
another thing I noticed - I am happy to see (i can import and rename them) my nikon coolpix p330 pictures - but something is wrong with the colors - they are greenish. No chance to correct that with white balance settings ...
See screenshot - first picture developed with photivo (here as a 16bit tif) second: jpg out of the camera and the raw as displayed by ASP:
too much contrast - green tint over the hole picture.
Has anybody noticed this problem with p330 pictures?
regards Hannes
austria
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Good to see that Corel have implemented the HDR module as promised, not sure that I will ever use it however.
Now if they could just sort out the WB issues with the Pentax K-5 Profile and give us a 64bit Gradfilter I'd probably be a happy user.
Interesting to see that the 64bit version of 2.1.0.40 under Linux mint 17 uses the correct theme and decorations for dialogues, etc.
Whilst the 32bit still uses the old style clunky dialogues.
Is this because I have the 64 bit version of Linux Mint?
R.
TheDude
System_Drive: N/A
motherboard: ASRock Z77
processor: Intel i7 quad core
ram: 32 GB
Video Card: saphire hd 5450 2xdvi
sound_card: on board
Monitor/Display Make & Model: Eizo S2410W & S2431W, calibrated with i1d2
Post by TheDude »
afx wrote: This is the first public version wit X-trans support...
Basically, it is pretty cool that they implemented X-Trans support. I opened some of my X-E2 images and unfortunately the demosaicing seems to be really poor. For example such artifacts as in the attached 100% crop:
Or is there any option I could have tweaked to avoid these artifacts?
This is the output from darktable without optimizations:
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
TheDude wrote:
afx wrote:For example such artifacts as in the attached 100% crop:
This was reported during beta testing.
Not that I've found.
I don't regard the x-trans support as usable at this stage, which is a pity as I don't think that it's too bad otherwise. Certainly way better than the initial LR attempt, apart from the issue you highlighted.
Arnfinn
operating_system: Windows 8.1
motherboard: ASUSTeK Computer INC. SABERTOOTH X58 Rev 1.xx
processor: Intel Core i7 CPU 960 3.20GHz 3.20GHz
ram: 12 GB
Video Card: NVIDIA GeForce GTX 670
sound_card: High Definition Audio Device [5x]
Hard_Drive_Capacity: 12 TB
Monitor/Display Make & Model: BenQ G2400W 24,0" + Acer X203H 19,9"
Corel programs: ASP
Post by Arnfinn »
I feel a bit degraded when there's no Pro in the name anywhere in the application work area, unless I open the splash screen under Help > About Aftershot 2...
That is by far the only place it says I'm running the Pro version. Everywhere else, it's just AfterShot 2 :?
Yes, I do have HDR and everything else, but please Corel; If I purchase the PRO version, I would certainly want to have it appear that way, and not be left with the low down feeling of the stripped down entry level version when working with my images...
Long time AfterShot Pro & Bibble user...
http://creativewithlight.com/
afx
System_Drive: N/A
Post by afx »
Arnfinn wrote:but please Corel; If I purchase the PRO version, I would certainly want to have it appear that way, and not be left with the low down feeling of the stripped down entry level version when working with my images...
ROTFL.....
afx
