I want to create a script that automates the command Adjust > Brightness and Contrast > Levels, where I would normally click on the 3 buttons in the Auto box (Contrast, Color and Levels). If I record a script, it seems to capture the values for that particular photo. Whereas I want the script to simulate me clicking the "auto" buttons and so apply the correct levels for each photo it runs on. Does anyone know how to do that in a script?
I can tell it's not correct because if I try it on a variety of photos, the results are different if I do the commands manually vs running the script.
Below is the part of the script that recorded the command I wanted. You can see it's got hard-coded values for the Red/Green/Blue levels etc, and isn't actually working them out for the photo it's being run on.
I'm using PSP X6 (64 bit) but I'm sure the question would apply to any version.
I really need to find out how to do this, so would really value any help or advice. I'm told Photoshop can do it, so I'm sure there must be some way to do it in Paintshop Pro.
Michael
# Color Adjust Levels
App.Do( Environment, 'ColorAdjustLevels', {
'Levels': {
'RGB': (6,255,1.00581,0,255),
'Red': (0,255,1,0,255),
'Green': (0,255,1,0,255),
'Blue': (0,255,1,0,255),
'Clipping': 0
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((16,0,0),1)
How to script "Auto Levels"
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Re: How to script "Auto Levels"
What I have done, and you can do, is to edit the script to the 'default' colour settings:-
'Levels': {
'RGB': (0,255,1,0,255),
'Clipping': 0
Then you run the script and press one of the buttons e.g. 'Levels'
This works well form me as the last step in a series doing HighPassSharpen, Clarify and ColorAdjustFillLightClarity.
'Levels': {
'Clipping': 0
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Many thanks for the quick reply - I'll give that a try. What I was really after is a way to script the "auto levels" so I can batch process a set of images using that script, to do the auto contrast/color/levels on each one automatically. Do you know how to do that?
Regards
Michael
Regards
Michael
Tadjio
- sound_card: Sound
You can't!mbourla wrote:Many thanks for the quick reply - I'll give that a try. What I was really after is a way to script the "auto levels" so I can batch process a set of images using that script, to do the auto contrast/color/levels on each one automatically. Do you know how to do that?
Regards
Michael
Tadjio
That's not what I was hoping to hear
. I'll just have to use a script but press the buttons each time for each photo. Not the end of the world I suppose. Thanks again for your help.
Tadjio
- sound_card: Sound
Believe me, I did try too. Now I am just happy to press the buttons each time...mbourla wrote:That's not what I was hoping to hear. I'll just have to use a script but press the buttons each time for each photo. Not the end of the world I suppose. Thanks again for your help.
Tadjio
Tadjio
- sound_card: Sound
Two further thoughts about "Auto Levels":-
1) I set the Levels "Options" Histogram Clipping to the minimum possible i.e. 0.01% (Lower and Upper Levels) and the Strength to 100%
This ensures minimal clipping when you press "Auto Levels".
2) You can use the Control Key when sliding the Highlights and Shadows sliders in order to see Technicolor Clipping Warning.
This really helps to see where "Auto Levels" will affect the image.
Tadjio
