Hi all, testing X7 for possible purchase. So far Im leaning toward X7 over either Adobe or Cyberlink.
The one issue that is preventing me from purchasing today is that the "Hint Bubble System" is broken on my rig. The Hint Bubbles are all chopped off at the bottom making them useless.
Ive determined the issue is related to my Nvidia Control Panel "Display Surround"" being enabled. I use this option on, ALWAYS. I like all 3 displays to use a single resolution of 5760x1080. When I disable it (3 individual monitors) the Hint Bubbles work as they should.
Does anyone know of a fix is available or in the works? This issue could force me to the competitors.
Hint Bubble's cut off at bottom
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Hint Bubble's cut off at bottom
Can you show us how it chopped?
You have a non standard screens set up. I don't know if there is a fix for the "Hint Bubble" and what so important about it once you master VSX7? VSX7 has many merits (and few flaws) but if this tiny culprit force you to the competitors, than go ahead. I'm sure once there you will find other culprits much more disturbing than the one you mention here.
Panasonic X900m, VXF1
