Is it possiple to create BlueRay image on USBstick?
Leif M
motherboard: -----
processor: -----
Video Card: -----
sound_card: -----
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: -----
Post by Leif M »
Hello friends!
When I have edited my video in X7, - is it then possiple to create USB-stick with my video with menu-structure?
IF it is possiple - What do I do - How do I do it??
Looking forward to hearing from You!
Many greetings
Leif
From Denmark :D :D :D
Re: Is it possiple to create BlueRay image on USBstick?
Post by BrianCee »
Well - - - -
If when you have your project in the timeline you go "Share >> Disc" you will see an option for "SD Card"
So some of us thought - if you can make it work from an SD card why not from a USB stick and we made an SD card and then copied from the SD card to a USB stick.
Now for some people that worked - but for me it didn't - what did work for me was to create AVCHD folders and copy them to a USB stick - but I found on my system that the menu didn't work doing that - apparently it can do for some..
You create AVCHD folders by selecting that option on the final screen of the "Create Disc" module
So unless someone else comes along with a simple solution I am afraid you need to experiment with those options and see if your hardware will function with it - it seems to me to be as much about your playing equipment as any thing..
