I am running windows 98SE, with 512 meg of ram, and a 1gHz processor.
Does anyone have any other suggestions? Thanks.
trevor andrew wrote:Ok
When you uninstall Vs also uninstall Smart Sound
Delete all remaining SmartSound and quick track folders.
I did all that too.
When you reinstall VS 9 the process pauses for quite a while before the quicktracks start installing. 26 music files should be installed.
If you do not uninstall smartsound then the install process will skip the new installation.
The smartsound files are there (c;/smartsound) I just can't access them in VS9.
The delay in starting the smartsound install is that long you may assume the process has stopped or complete, be patient.
I let the quicktracks.exe file sit for about 5 minutes and nothing happens. The installation disk is accessed, but the executable file doesn't run.
Hope this Helps
