Green background remove?
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
Some tips how to do it or tip on plugin for VS X7?
I mean remove green background ..to make it transparent.
Thank you.
Re: Green background remove?
Post by BrianCee »
Put the video you are going to use as the background in the top video track
Put the video with the green background in an overlay track and make sure it is selected.
Open the Options panel and select the "Attributes"tab - then select "Mask and Chroma Key"
In the new dialogue box which opens click to put a tick in the little box next to "Apply Overlay Options"
Usually that is enough and VideoStudio automatically selects the correct settings - but you will see there are options to 'tweak' settings if needed.
The image below was done with a blue background - but it demonstrates what you should see
click on the image to enlarge it
Radim
ram: 4GB
Post by Radim »
Thank you.
