X7 crashes when I attempt to activate Balls & Bubbles
Gold Acres
processor: 2.00 gigahertz Intel Core2 Duo
ram: 4GB
Hard_Drive_Capacity: 3TB
Corel programs: X6, X7 & X8
Post by Gold Acres »
I am on a brand new computer with a ton of memory. I am trying to create a bubble effect. X7 has crashed now on me 4 times. Everything is fine until I select Balls & Bubbles, even on a blank white canvas. I am not happy today! :roll: :cry:
So, I am wondering if anyone else has this problem or a solution for it...?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: X7 crashes when I attempt to activate Balls & Bubbles
Post by Kathy_9 »
Balls & Bubbles works fine for me on X7 so it's not an across the board issue.
You could try resetting your workspace as that seems to fix a number of issues. If you have made customizations be sure to save your workspace first. Then close PSP X7 and re-open it by double clicking on the desktop icon while holding the shift key. It will ask if you want to revert to default (or words to that effect) and you should click OK.
If that doesn't work you could open a support ticket with Corel.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Balls and Bubbles works OK here on an XP machine and 32 bit version.
Gold Acres
ram: 4GB
Kathy_9 wrote:Balls & Bubbles works fine for me on X7 so it's not an across the board issue.
Can't do the support ticket cause my membership is expired... However the reset worked!!! :D :D :D Thanks for the suggestion.
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Post by trueblue »
I thought you had fixed this after resuming PSP to default?
I'd say this is a glitch and not a bug as I and others are not experiencing this problem.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Gold Acres
ram: 4GB
Gold Acres wrote: However the reset worked!!! :D :D :D Thanks for the suggestion.
Dizzie
motherboard: dunno
processor: dunno
ram: 6 GB
Video Card: dunno
sound_card: dunno
Hard_Drive_Capacity: 500
Post by Dizzie »
Reset worked for me too...thanks for posting it.
Muriel
Post by Muriel »
Good Evening!
I had this issue with PSP X6 and Windows 8 and finally bowed to defeat and functioned without the Balls & Bubbles feature.. too bad because it is one that I use frequently in earlier versions and operating systems. Today I purchased Version X8 with the misplaced confidence that whatever this glitch/bug/whatever this is has been well and truly rectified by this time. Not so...
I tried this default exercise with Version X8 and Windows 10, and BINGO! IT WORKED! I ws thrilled to bits, but then I reinstalled the File Locations and it reverted back to his non-working mode where it is most comfortable. I do use this feature frequently and miss not having it. Any suggestions from those among us who are more technically gifted than I am are most welcome.
Muriel!
Gold Acres
ram: 4GB
Do you have your own Environment and Displacement Maps in any of those files? One of them could be the cause of it's not working correctly.
Muriel
Post by Muriel »
Good Afternoon Merlene..
Thank-you for your quick reply.. seems I am no longer alerted via e-mail when a reply has been posted.
And yes, yesterday I reverted it to its original state and gradually reinstated all the adjustments. It seems the Environmental Maps folder may well be the issue, but since there is always an another annoying glitch just waiting to tease me, I noted that the outside bevel and chisel options were grayed out. So I am in the process of reinstalling it, and with any luck at all, I shall prevail and it will work for me. I began this relationship with PSP when Version 8 was first introduced, and all the early versions worked like a hot damn for me. I wonder why there are so many issues with the bigger and better later ones.
Gold Acres
ram: 4GB
Personally speaking, I think they are more interested in adding new things than putting out a stable product. But then we have had so many changes in Operating systems in the last few years, it must be difficult to put out a product that works across all of them.
