Can't set project to 2560x1440
Cantisque
motherboard: ASUS ROG Strix X570-E
processor: Ryzen 9 5900X
ram: 32GB
Video Card: ASUS TUF RTX 3080Ti 12G
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: LG Ultragear 27gl850-b
Corel programs: VideoStudio Ultimate 2021
Post by Cantisque »
As title states, the option to set a custom frame size in project settings is greyed out no matter what type of video I choose and 2560x1440 does not appear in any of the presets, please help!
Re: Can't set project to 2560x1440
Do you actually have video in that frame size? If so, where did it come from? If you are using Video Studio X7, have you ticked, in Preferences > General the box beside "Show message when inserting first video clip"? If that is ticked, and you insert the video clip with that frame size, do you get a message asking if you want the Project Properties to match the properties of the clip? If so, then you would be able to go to Share > Same As Project Properties.
If not, then I suspect VS just can't deal with that frame size -- which off hand I would have to guess is some variant of 4K video...
Cantisque
ram: 32GB
Post by Cantisque »
These are game recordings, 1440p (QHD), same resolution as my display.
I checked the box, started a new project and it would automatically set the project to the correct size.
Thanks!
Cantisque
ram: 32GB
Post by Cantisque »
Spoke to soon, when I try and render the video, having ticked the "same as project settings" box, nothing happens when I click the "Start" button.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Cantisque wrote:Spoke to soon, when I try and render the video, having ticked the "same as project settings" box, nothing happens when I click the "Start" button.
I did a test with this dimensions. Using a different software I produced a short clip 2540X1440 made from Jpegs .
It was uncompressed AVI. I imported it to VSX7 timeline. My project was set to that but....
when I wanted to render it as "same as project settings" I couldn't change the encoder or compression they all grayed out. It could be only be rendered as uncompressed AVI.
So I went to project settings selected AVI profiles > new > and there I could confirm to resolution and compressor. None of the other options will allow me to set resolution.
So I rendered a XVID AVI file.
** Well, I manged to produce on the other software an H.264 2560X1440 .mp4 clip.
I loaded it to VSX7 and you are right, it will not render with those settings, the only way out is as AVI with XVID as I wrote above.
This is my test clip
Panasonic X900m, VXF1
Cantisque
ram: 32GB
Post by Cantisque »
Would I need to install Xvid to do that? Because the only driver I can choose is the Ulead one by default.
Edit: That worked, but the output isn't as sharp as I'd have liked, I will have to mess with the settings and see what I can come up with. Thanks!
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Cantisque wrote:Would I need to install Xvid to do that? Because the only driver I can choose is the Ulead one by default.
Messing with settings is part of the fun...
Try this profile I made for you, put it the Corel VideoStudio Ultimate X7\Ulead.dat\WMV_Profiles folder
Than you can select it for rendering. it's GAME Capture Profile 2560X1440 at 20MB video, 192K audio 25 fps.
And if you need different settings, than open the .prx file in notepad and "mess" the settings to your needs :lol: :lol: :lol:
Corel Screen Capture Profile 2560X1440.zip
(1.07 KiB) Downloaded 178 times
Cantisque
ram: 32GB
Post by Cantisque »
That looks great, thanks! Unfortunately it seems to always default to 25 FPS instead of 30. I've checked the file in Notepad but I can't see which one I would need to change for this. Really big help though, thanks!
Edit:
Changed avgtimeperframe to 333333 and that fixed it, thanks again!
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
U C , I told you that messing the settings is fun.
