Flash Objects Vol. 2 & VideoStudio UX7
smeogan
motherboard: Biostar B350 GT5 Racing
processor: AMD Ryzen 7 1700x 3.4ghz
ram: 32GB FURY
Video Card: Sapphire Radeon RX 580 8gb Gddr5
sound_card: Sound Blaster X-FI Platinum
Hard_Drive_Capacity: 512GB SSD
Monitor/Display Make & Model: Asus VP228QG
Corel programs: VS 2018
Post by smeogan »
Hello, I have VideoStudio Ultimate X7 and i am interested in Flash Objects Vol. 2 but i dont know if they are compatible. Does anybody tried them together? Thanks!
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Flash Objects Vol. 2 & VideoStudio UX7
Post by asik1 »
smeogan wrote:Hello, I have VideoStudio Ultimate X7 and i am interested in Flash Objects Vol. 2 but i dont know if they are compatible. Does anybody tried them together? Thanks!
What Flash objects? from where? why they shouldn't?
Panasonic X900m, VXF1
smeogan
ram: 32GB FURY
Post by smeogan »
This Flash Objects Vol. 2: http://apps.corel.com/ap/2012_FlashObje ... ex_sea.htm
Wrote for VideoStudio X4 but i was wondering if it's compatible with my VideoStudio Ultimate X7
Thanks!
You should certainly be able to insert them in your projects since X7 can accept .swf files (which is the format of those flash files). However, if you intend to make more .swf files from them, just be aware that Video Studio no longer can produce swf flash files. Instead it uses the new flash format WebM for output (Share > Custom and then select WebM from the output formats).
smeogan
ram: 32GB FURY
Post by smeogan »
Ken Berry wrote:You should certainly be able to insert them in your projects since X7 can accept .swf files (which is the format of those flash files). However, if you intend to make more .swf files from them, just be aware that Video Studio no longer can produce swf flash files. Instead it uses the new flash format WebM for output (Share > Custom and then select WebM from the output formats).
Thank you for your answer. I appreciate. So just to confirm, i could edit these swf files in VideoStudio X7 and save them as WebM to make my own flash animations from these samples/templates? Or do i need a different program to edit them? Can i mix these flash files with my video files? I dont know much about video editing for now so i am planning to learn.
By the way, is there anybody here that created free samples/templates that we can download? Like multi frame/screen, flash animations, anything etc. It's kinda hard to find some on google. Tho I'll probably purchase the 3 Flash Objects Volumes if everything works with X7, these are pretty nice effects. Does anybody knows if is there anything else like that from corel or partners that i could puchase? :) Thank you!
You can certainly mix them with other format videos. That is what they are for, after all. And you can output them in either WebM or other formats, but not swf. As for editing them and outputting them in WebM format for later use, that too should be possible, but only if you needed to edit them. Otherwise, just leave them in swf format (i.e. unedited).
smeogan
ram: 32GB FURY
Post by smeogan »
Alright thank you :)
