Is there a way to extract text information from an old .pspimage file? I.e. font name, size and attributes --
I have the effects used saved in an 'effects file,' but can't find the font used....
I have PSP X3, X4 and X6
Old Image - What Font and effects Did I use?
rjw918
- motherboard: Dell Computer Corporation
- processor: 1.50 gigahertz Intel Pentium M
- ram: 1024 MB
- Video Card: NVIDIA GeForce FX Go5200
- sound_card: SigmaTel C-Major Audio
- Hard_Drive_Capacity: 40G
- Monitor/Display Make & Model: Insignia DX-19L150A11 [Monitor]
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Re: Old Image - What Font and effects Did I use?
This will only work if you don't have the font you used installed. If you used vector text and kept the vector layers intact, you should be able to get the font info by opening the image. You'll get a warning if the font you used isn't installed and it will show the name of the font that was used. Obviously this won't help if you used a font that is always installed. If that's the case, you could ask someone else to try opening the file and see if they get the error message.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
If it's still a vector, and they can open the file, won't editing the text show the currently selected font? So having the font installed or not shouldn't matter.
Now, if it's not vector text you could use a dedicated font website that can analyze images and give you potential font matches. But you'll have to save a copy as a JPG and make sure the text can be clearly distinguished.
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Can we see the image, maybe someone recognises the font
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
If an effect has been applied to the text, it has likely be converted to a raster, therefore the information would be lost.
Then, the only way to retrieve that information will be with LeviFiction's suggestion.
Cassel
https://scrapbookcampus.com
LindaSue
- ram: 3 GB
You're right, LeviFiction. As soon as you click on the text with the Text Tool, the font list switches to the font that was used. I never thought to check there but then I rarely run into this issue. When I do, it's because I don't have the font installed and I get the error message.
