Plugins and PSP X7
Plugins and PSP X7
I have found that all my 8bf plugins are greyed out in PSP X7, 32 bit. Is there a solution? I have had them all working in 32 bit versions of PSP from 9 to X6.
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Plugins and PSP X7
Without knowing specifically which plug-ins , it's hard to say. Most of my plug-ins work in 32-bit X7 but some older ones do not. Since this isn't your first version of PSP I'm assuming you have set the file location to point to your plug-in folder(s).
If you tell us which plug-ins someone might be able to confirm if they have the same plug-in on their system.
Plugins that are greyed out include:
All are OK in PSP X6.
I have been asked to give a demonstration of X7, otherwise I just would not bother and stick with X6.
- Transparency
Virtual Painter
Toadies
Simple
FM Tile Tools
Kathy_9
The only one I have that I can check is Toadies and it works if you import it into Filters Unlimited. It does not work in X7 on it's own.
Others have complained about Mura's Meister filters not working and Corel is aware there is a problem but there is no guarantee they will fix it.
