snapshot size different with video size
evonne
Post by evonne »
hi,
was trying to take a snapshots (Bitmap) in creating a video, but why the size of the picture is differ with the size of the video after rendered out ?
pls help. thanks.
Re: snapshot size different with video size
Post by BrianCee »
Are you rendering to the same size as your original video ?
Are you taking the snapshot in 'clip' or 'project' mode ?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
and if you could tell us the size of the original and the size you ended up with that might help.
Taking a snapshot in Clip mode will use the clips frame size, this is ok when using HD 1920 x 1080, but if you are working with SD 16:9 then 720 x 576 will be used. (assuming Pal)
Taking in Project mode will create an image as seen on the preview window for Pal that will be 1024 x 576, and the same shape as your video.
Simply select the word Project adjacent to the play button , then Edit – Take a Snapshot
