since a few days my VS Pro X7 crahes when I try to transform MOV files to M2TS files. Nearly at the end the program freezes. A file was created but the end is loosing, sometimes the Sound is also bad.
What's wrong? What can I do?
Some weeks before such things worked....
I tried to deinstall Quick time and installed the new Version again without a result.
I tried to disable SmartRender without a result...
Hope somebody can help me.
VS X7 crashes MOV
Re: VS X7 crashes MOV
If the render process has been successful in the past then either something has changed on your pc or you are using different types of video or different settings.
Have you installed any other software that may be conflicting with VS.
Please right click your clips in the timeline and select properties -- what are they?
If the program freezes at say 90%, what is in the timeline at that point.
When you “transform the Mov files” just what are you pressing to do that? give us more details.
I assume Share – Avchd
Finally what are you trying to make, a video for the internet or a bluray disc?
sorry for my late answer.
I have Problems to render MOV Files from a Nikon Camera to M2TS.
The properties:
1920x1080
9.009 sek
1 Video 1 Audio
AVC Coding
24Bit 1920x1080
270 Pictures
29.970 pic/s
9009 sek
0000 sek
MPEG 4 Low Complexity AAC
48.000 16 bit Stereo
432.128
9.003 sek
0.000 sek
I want to convert it to AVC/H.264 (own properties):
- 25 pic/sek
- upper Frame first
- 1920x1080
- PAL HDMV
- Komprimierung 100%
- AVCHD
- Variabel max 16800
- DolbyDigital 3/2 384 kbps
With the MOV Files from my Canon it works. Not with the Nikon.
I only deleted an old add-Program vom the Version before (VideoStudio Pro X5): Boris Grafitti or so.
Now I tried again, the Video Studio doesn't stop the working, but the result has a Sound Problem. At the beginning it's good and then noises.
The properties:
1920x1080
9.009 sek
1 Video 1 Audio
AVC Coding
24Bit 1920x1080
270 Pictures
29.970 pic/s
9009 sek
0000 sek
432.128
9.003 sek
0.000 sek
- 25 pic/sek
- upper Frame first
- 1920x1080
- PAL HDMV
- AVCHD
