Script command "App.Setonly()" instead of "App.Do()" avail?
pstein
Corel programs: PSP X2
Post by pstein »
Is there a command for Scripts which only sets parameters BUT NOT EXECUTE/APPLY an operation?
Something like:
App.Do( Environment, 'ColorAdjustBrightnessContrast', {
'BrightnessContrast': {
'Brightness': -12,
'Contrast': 0
'GeneralSettings': {
'SetonlyMode': App.Constants.SetonlyMode.Default,
'AutoSetonlyMode': App.Constants.AutoSetonlyMode.Match,
'Version': ((12,0,1),1)
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Script command "App.Setonly()" instead of "App.Do()" ava
Post by LeviFiction »
As far as I know, no there is no other command. (Well, if you use the inspect module there are other names that show up but nothing like what you want)
Are you trying to set the values inside the UI? Or, why would you want to set the values without executing the command?
If you're trying to set the values in the UI, no there is no such link inside of PSP. Only presets can be used to set the values for a tool or dialog. However, if you enter "intereactive" mode then dialogs will show the values that you set. But they have to be accepted or else they won't stick.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
But you can do/execute something simple and fast...like draw small rectangle or something that use this (your's) specific settings and then delete it. Even keep history commands unchanged. :P
pstein
Post by pstein »
Radim wrote:But you can do/execute something simple and fast...like draw small rectangle or something that use this (your's) specific settings and then delete it. Even keep history commands unchanged. :P
Ok. Sounds good
...and how do I delete/undo an operation from a script?
Radim
ram: 4GB
Post by Radim »
pstein wrote:...and how do I delete/undo an operation from a script?
Code: Select all
App.Do( Environment, 'UndoLastCmd')
Radim
ram: 4GB
Post by Radim »
Here is my attempt. It sets Foreground and Backgroud colors (red and yellow).
Code: Select all
from PSPApp import *
def ScriptProperties():
    return {
        'Author': u'',
        'Copyright': u'',
        'Description': u'',
        'Host': u'PaintShop Pro',
        'Host Version': u'16.00'
def Do(Environment):
    # New Raster Layer
    App.Do( Environment, 'NewRasterLayer', {
            'General': {
                'Opacity': 100,
                'Name': u'Raster 2',
                'IsVisible': True,
                'IsTransparencyLocked': False,
                'LinkSet': 0,
                'UseHighlight': False,
                'PaletteHighlightColor': (255,255,64),
                'GroupLink': True,
                'BlendMode': App.Constants.BlendMode.Normal
            'BlendRanges': {
                'BlendRangeGreen': (0,0,255,255,0,0,255,255),
                'BlendRangeRed': (0,0,255,255,0,0,255,255),
                'BlendRangeBlue': (0,0,255,255,0,0,255,255),
                'BlendRangeGrey': (0,0,255,255,0,0,255,255)
                'ExecutionMode': App.Constants.ExecutionMode.Default,
                'AutoActionMode': App.Constants.AutoActionMode.Match,
                'Version': ((16,0,0),1)
    # CreateRectangleObject
    App.Do( Environment, 'CreateRectangleObject', {
            'Antialias': True,
            'MiterLimit': 15,
            'Join': App.Constants.JointStyle.Miter,
            'CreateAsVector': False,
            'Fill': {
                'Color': (254,255,3),
                'Pattern': None,
                'Gradient': None,
                'Texture': None,
                'Art': None
            'LineStyle': {
                'Name': u'',
                'FirstCap': (u'Butt',7.21,7.21),
                'LastCap': (u'Butt',1,1),
                'FirstSegCap': None,
                'LastSegCap': None,
                'UseSegmentCaps': False,
                'Segments': None
            'LineWidth': 1,
            'Stroke': {
                'Color': (255,71,7),
                'Pattern': None,
                'Gradient': None,
                'Texture': None,
                'Art': None
            'ObjectName': u'New Rectangle',
            'Left': 11.5,
            'Top': 11.5,
            'Width': 19,
            'Height': 21,
            'RadiusX': 0,
            'RadiusY': 0,
            'Matrix': None,
            'Visibility': True,
                'ExecutionMode': App.Constants.ExecutionMode.Interactive,
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
You can use these for setting colors:
Code: Select all
    # SetMaterial
    App.Do( Environment, 'SetMaterial', {
        'IsPrimary': App.Constants.Boolean.false,
        'NewMaterial': {
        'Color': (255,255,0),
        'Pattern': None,
        'Gradient': None,
        'Texture': None
    # SetMaterial
        'IsPrimary': App.Constants.Boolean.true,
        'NewMaterial': {
        'Color': (255,0,0),
        'Pattern': None,
        'Gradient': None,
        'Texture': None
Cassel
https://scrapbookcampus.com
