AC3 problem
iradel
AC3 problem
DVD MovieFactory 4 seems to have a problem converting files (divx in particular) that have AC3 sound. Right at the end of the conversion step, it just fails.
Is AC3 officially supported?
iradel
partial solution
Nomatter what I did, I could not get the conversion step in MovieFactory to succeed on a divx (avi) file with AC3 sound. As a test, I re-encoded that file again except with mp3 sound. At that point, the conversion step in MovieFactory went just fine and the file burned successfully to DVD.
What do you mean by "licensed AC3" ? The file with AC3 sound had to be encoded/ripped by some certain application for it to work in MovieFactory?
iradel
XiHuCuYu
Re: AC3 problem
Hi, I am having exactly the same problem. Did you find a solution?iradel wrote:DVD MovieFactory 4 seems to have a problem converting files (divx in particular) that have AC3 sound. Right at the end of the conversion step, it just fails.
CY
iradel
Re: AC3 problem
No, I have not found a solution. I have been trying to convert the file to one with mp3 (instead of ac3) with virtualdub, but the audio and video end up out of sync no matter what I do. If MovieFactory worked right, I wouldn't have wasted a week of work.XiHuCuYu wrote:Hi, I am having exactly the same problem. Did you find a solution?iradel wrote:DVD MovieFactory 4 seems to have a problem converting files (divx in particular) that have AC3 sound. Right at the end of the conversion step, it just fails.
CY
maddrummer3301
Maybe not. Your file is probably 5 channel of sound.
Could you post the Name of the video your trying to convert?
Could you post how you created the video? What program/download?
The above post that compares the 2 products says AC-3 Dolby® Digital (AC-3) Stereo audio encoding
Stereo is 2 channel. Mpeg audio is 1 or 2 channel.
Right-Click on the file when it's on the timeline and select "Properties"
then post that information back to this thread.
MD
MD
XiHuCuYu
Re: AC3 problem
Try Nero Ultra 6.6. I have convert the avi file for which MF4 is having trouble. Better, it's much faster than MF4, 2-3 hrs vs. 10-12 hrs. Make sure to get the full version and all the plu-in's.iradel wrote:No, I have not found a solution. I have been trying to convert the file to one with mp3 (instead of ac3) with virtualdub, but the audio and video end up out of sync no matter what I do. If MovieFactory worked right, I wouldn't have wasted a week of work.XiHuCuYu wrote:Hi, I am having exactly the same problem. Did you find a solution?iradel wrote:DVD MovieFactory 4 seems to have a problem converting files (divx in particular) that have AC3 sound. Right at the end of the conversion step, it just fails.
CY
CY
