Text size
Nok
processor: Intel Core i5
Hard_Drive_Capacity: 220G
Monitor/Display Make & Model: Samsung 17inch
Text size
Post by Nok »
I have created an interactive script that lets the user select a font and enter the text size. The problem is that the created text is way smaller than the text size I entered. For example if I enter 30 as the text size, the text is created as 14px or 5 points. My image uses pixels for units and has a 200ppi resolution. I think there is some formula that PSP uses to determine the size of the text. How can I change my script such that if I enter 30, my text will have 12px as its size or 5 in points?
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Re: Text size
Post by Cassel »
Depending on which version the script is used in, that is a real challenge. As soon as the pixels/points option appeared, scripts have had no way to always use the same unit all the time. You can run the script 10 times, and the size will use pixels, and then, next time, it might use points. It is a problem that didn't seem to have an explanation, so a solution is not easy.
I wrote a snippet that makes the script check itself. Can you send me your email and i can send it to you with some explanation on how it works and how you might need to edit it depending on the image resolution if that could be an issue (it is not for me, so i never changed that).
My email is cassel AT creationcassel DOT com
Cassel
https://scrapbookcampus.com
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: Text size
Post by Radim »
Cassel wrote:I wrote a snippet that makes the script check itself. Can you send me your email and i can send it to you with some explanation on how it works and how you might need to edit it depending on the image resolution if that could be an issue (it is not for me, so i never changed that).
I am curious too... :P
