Python version
Nok
- processor: Intel Core i5
- Hard_Drive_Capacity: 220G
- Monitor/Display Make & Model: Samsung 17inch
Python version
How can I determine which version of Python PSP uses?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Python version
PSP uses a basic installation of Python so it includes all of the base libraries from sys, to ctypes. Event TKinter.
So all you would need to do inside of PSP is create a script that called and printed sys.version. Of course, to use those libraries the script must be placed inside your scripts-trusted folder.
Another way is to look at the program files inside of PSP. You'll find a DLL labeled CorePython##.dll
Using the DLL method
CorelX7 uses Python 2.7
Using the sys.version method
CorelX7 uses Python 2.7.5
So depends on how detailed you want to be.
Code: Select all
from JascApp import *
import sys
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'',
'Host Version': u''
def Do(Environment):
print(sys.version)
Nok
Re: Python version
Thanks LeviFiction.
I ran the script and got 2.6.5 in PSPX5 and 2.7.5 in PSPX6.
