Can VSX7 create a simulated super slow motion effect like this
http://deadspin.com/antonio-brown-kicks ... 1631681037
Super slow motion
qtrim
- motherboard: ASUS P5QL PRO 775 P43
- processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
- ram: 4GB
- Video Card: NVIDIA GeForce 9400 GT
- sound_card: Onboard Asus Audio
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Super slow motion
Using VideoStudio since old Version 7. Currently using X10.
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: Super slow motion
To get that level of quality slow motion, you need probably two things. One is to capture the action with very high frame-rates. And two, use software that adds high quality carefully interpolated frames in between each frame. Video Studio does not do this.
I have done this using a 24fps clip, not really very fast frame-rate, where I added many frames in between each frame. The clip was of a waterfall which is not as hard as the clip you linked. It worked pretty well, but it was a lot of work and a lot of time. I did it mostly to learn how this is done... Al
PS Click this old forum post for my waterfall video
http://forum.corel.com/EN/viewtopic.php ... es#p229490
User for more than 10 years.
I agree that VS can't do it properly. I bought an excellent proDAD program called Respeedr which does it beautifully and without too much of a learning curve. Unfortunately, it is not particularly cheap (US$99). I bought it when it first appeared and they had a special introductory price.
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
The clip you supplied was in itself jerky and it was easy to see the frame jump.
If you are seriously into slow motion, first get a camera that does Slo-Mo such as the Panasonic HC-V750 (757), the Slo-Mo produces a file at 1/2 speed and, in playback mode, a file at 1/4 speed. This is a good starting point for VS X7 to slow the footage down especially in the UK version it records at 100 fps.
Following the installation of Service Pack 1, X7 will happily mix MP4 and AVCHD files and I have produced videos with Slo-Mo incorporated in them.
grahamteenapaul
- motherboard: TOSHIBA VG10S
- processor: 2.40 gigahertz Intel Core i7-4700MQ
- ram: 8106 MB
- Video Card: Intel HD Graphics 4600 NVIDIA GeForce GT 745M
- sound_card: NVIDIA Virtual Audio Device Wave Extensible
- Hard_Drive_Capacity: 1000.10 GB
- Monitor/Display Make & Model: Generic PnP 15.3 inch and Samsung S24C350
Showing 120 fps clips at 25 fps to get slow motion?
Hi, I have a related question: how can VideoStudio 6 be made to display a high frame rate movie clip at 25 fps so that it appears as nice3 smooth slow motion?
I have a GoPro Hero4 which records 1920x1080 at 120 fps. Inserting this into VideoSudio 6, it tries to play it at full speed 120 fps -- and it's jerky, perhaps because it can't process all the video data at that rate or perhaps because it's trying to convert it to the project's frame rate, I don't know. I've tried using the variable speed control and setting it to 20% speed, and that certainly slows it down but it's still very jerky even when rendered and clearly isn't displaying all the original frames at 25/sec. Is there any way VideoStudio 6 can be persuaded to think that the 120 fps clip should be shown at 25 fps, ie at approx 1/5 of real-life speed?
Regards, Graham Paul
