I'm having problems with Paintshop Pro X6 after installing it on my new Windows 8.1 laptop. It worked fine on my old Vista Desktop. If I open a 10mb image and do some editing on it (doesn't matter what kind of editing) and then "SAVE" it, the file size goes to less than 2mb. If I do a "SAVE AS" instead, I don't get the file size reduction, in fact it goes up a bit. I've gone into the Save Options and made sure Encoding is set to Lossless Encoding. When I look at the reduced file, the dimensions are the same (5540x 3698) and the file is still 300dpi. This is very annoying and I'm struggling to find the problem. Can anyone help?
Doug
Reduced File Size after save
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: Reduced File Size after save
The compression is set to 20, so every time you save it compresses the file size.
I only use Save As and have set the compression under Options, set to 1.
It is very tempting to click on Save when the message box pops up, but using the F12 key (Save As) only, saves a lot of frustration!
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Tadjio
- motherboard: Gigabyte
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
What version of PSP where you using on your old Vista Desktop? Was it also X6 or an earlier version?DBrook wrote:I'm having problems with Paintshop Pro X6 after installing it on my new Windows 8.1 laptop. It worked fine on my old Vista Desktop.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
DBrook
- motherboard: LENOVO VIQY0Y1 31900058STD
- processor: 2.40 gigahertz Intel Core i7-4700MQ
- Hard_Drive_Capacity: NVIDIA GeF
- Monitor/Display Make & Model: Samsung S22D390
Joelle - I have Lossless Compression selected so the compression slide bar is disabled. Mine is at 1 anyways.
Tadjio - I had the same program X6 installed on my Vista Desktop.
Tadjio
- sound_card: Sound
What File Type (extension) are you using?
Tadjio
Hi Guys
I see similar results. Using X4 and X7
Original image is 860Kb, Chrysanthemum.jpg from Windows Picture library
If I “save as” and set the compression to Standard compression “1” then the resultant file is 594Kb
If I set Lossless then the new image is 673Kb.
DBrook
DBrook
I've been playing with this a little more and getting even more frustrated. If I open a jpeg in the Edit Tab, and do nothing but hit the Save Button, the fill size gets decreased greatly. So it appears to me that there must be some place where you should be able to change the Save Settings like you do with the Save As Settings. However, I can't find anywhere in the Preferences to do this. So it looks like every time I open a jpeg in Edit Mode, I have to do a SAVE AS to save it and get 2 files now. Then go back and delete the original file. There must be a way of changing the setting for SAVE.
Kathy_9
- Hard_Drive_Capacity: 2TB
Sorry but there is currently no way to change the Save setting.
Tadjio
- sound_card: Sound
As Kath says, there is no way to change the SAVE Compression. It is hard-coded into the program (or somewhere in the Registry but I can't find it;)DBrook wrote:So it looks like every time I open a jpeg in Edit Mode, I have to do a SAVE AS to save it and get 2 files now. Then go back and delete the original file. There must be a way of changing the setting for SAVE.
When you do a SAVE AS, you can overwrite the original by clicking on it, or click Save, or just press Return/Enter, and then saying Yes to replace it.
Tadjio
