hartpaul wrote:Are we placing the cart before the horse here?
We have an $80-100 program that can partially read the native files (psd); that come from an $800-1000 program so long as they are 8 bit and not 16 bit.
BUT when you try and drop a native pSP file (pspimage) I get the error message "Could not complete your request because it is not the right kind of document."
Why do we expect more from the economical cheaper program. Why is PSP being downgraded and called buggy in this case because it can't be fully compatible with the other programs files.
If PSP was priced at $800 + I would expect it to do everything and not have bugs.
I really like PSP. I am relatively new to it and had some trouble at the beginning because some of its adjustments are not "real time" in that you have to make the adjustment and then wait for it to show you what you will get rather than have it constantly adjust as you push a slider (as with Photoshop). But I have done some comparisons and found that I can make photos look just as good, perhaps better, using X7 as with PS CS5.1. What was the biggest surprise to me is that when I adjust a photo in CaptureOne (my workflow software), send it to X7, use the included version of Perfectly Clear, save it as a jpg and do the same with PS I cannot see the difference. I have come to really like X7.
Having said that it is clear that Photoshop is the standard and developed the standard file format in psd. Pretty much all pixel level photo editing software open psd files and none open pspimage files except other Corel products. Corel says that it is compatible with psd image files and I have never seen any statement that this compatibility is limited to 8 bit files. If they claim psd compatibility I expect them to have psd compatibility. Had they said they were only compatible with the 8 bit variety than I would not have filed the bug report nor posted about it on this forum.
In fact, of course, Corel does support 16 bit psd files. If I open a single layer 16 bit psd file in X7 it opens correctly, and in 16 bits. It is only multiple layer 16 bit psd files that X7 is having trouble with and, while discussing this with Corel support, I was constantly told that Corel supported psd files and no comment was made that this applied only to the 8 bit flavor. And, at its base, I am not sure that there really is such a restriction because I got a PM from someone at Corel support with the comment:
The issue you mentioned should not be existed.. He did not say it existed for 16 bit files, he said it should not exist.
As for bugs, I have never mentioned any bug issue with Corel's software except this issue. All software has bugs. All commercial software is so logically complex that with so many possible user paths through it that it cannot all be tested. During my time in the software industry before I retired I found that the average coverage rate for tested software was somewhere in the 40% range and the highest I ever saw was about 91% in spite of repeated efforts to increase that. So there will always be bugs. I have had PSP crash on me, freeze on me and perform strangely but I have not complained about that because that is expected. Photoshop does the same (although, perhaps, not as often). Hence service packs from both companies. It is the claimed compatibility that is an issue for me.
None of that means that I don't like the software (I do) and from the industry's point of view, if people don't raise these issues, they will probably never know of some of them and they will never get fixed. It may sound like I am whining and complaining but, believe it or not, I am trying to help them by calling attention to this issue so they can address it.
