strange wrong (inverted?) colors - old bug ...?
Bugs & Suggestions
hannes_hab
operating_system: Linux
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
I sometimes have strange inverted colors (picture and preview and output)
It only happens with raw files (from every camera I use)
It only happens if a switch back to an previous viewed picture. (for example if I would like to copy settings from this image)
No chance to get rid of it by making an refresh or switch from image to another image (the these image get the wrong color too ...).
The only way (I have found) to get rid of it is to close Aftershot and start it again. The the right colors are there again.
And - this is not new - it happens with all versions of ASP and even Bibble 5 (don't remember if it was there if earlier version of bibble). I "lived" with it - but now - ASP2 has other problems and crashes too - I really want to solve this problem.
Does anybody have an idea whats the problem - did anybody have this problem too?
I only notices it on linux (Suse 11.4 and Ubuntu 12.04) - but I dont work much on WIN ...
after clicking back on a picture viewed/edited before
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
FalCT60
Re: strange wrong (inverted?) colors - old bug ...?
Post by FalCT60 »
Hello,
Maybe some problem with your default settings (DefaultRaw.xmp and/or DefaultRendered.xmp) ?
J.-Luc
hannes_hab
System_Drive: Z
ram: 16 GB
thank you for your answer!
I copied the original raw-default from /opt/AfterShotPro2/supportfiles/defaults/defaults to the user folder.
the files are different (see screenshot) but the bug still exists (see screenshots).
I am wondering what the lines
bopt:hasSettings="true"
bopt:rn_smooth_enabled="true"/>
that are not in the (old) raw default file and are not in camera default file are for?
Second question - if I have a camera default file - then it still makes sense to change the raw default?
I think I should copy those lines in the camera default file?
regards Hannes
austria
FalCT60
Post by FalCT60 »
Hello,
I don't know. Mine are true / false. What happens if you try the ones in the appended rar ?
I use a D700, but I don't think this is much important.
Also, there is a file named "ResetAllSettings.xmp" that I got "I-don't-remember-where" on this forum and that seems to appear in the presets section from the standard tab that you might try as well.
BTW, would you mind sending me one of your NEFs ?
J.-Luc
defaults.rar
(1.35 KiB) Downloaded 155 times
