Is there a way to ...
MikeFromMesa
operating_system: Mac
System_Drive: N/A
processor: 3.0 GHz Intel Core i7
ram: 16 GB
Video Card: Intel Iris
Hard_Drive_Capacity: 256 GB SSD
Monitor/Display Make & Model: 24" Dell Ultrasharp Monitor
Corel programs: PaintShop Pro, AfterShot Pro
Post by MikeFromMesa »
I have noticed that X7 does not seem to remember the location where I just saved a previously edited file. Every time I do a Save As I have to navigate from it's default area to the place I want the file saved. And Save (compared to Save As) has it's own location where it wants to save files. I was wondering if there was a way to save all open files to the same location so I don't have to go through the browse selection for each and every file.
I checked the Preferences to see if there was a way specify where files should be saved, but could not find anything. I can, of course, just accept the specified location and then mass copy (or move) the files where I want, but I would think there was a better way to do this. Perhaps a way to set the save location, or an existing script that would save all open files to the same place. I could record saving a file but I don't know if that would actually help as I fear it might end up saving all files to the same location and name.
If I could find an existing way to do this it would be a help. Otherwise I am afraid I might have to sit down and learn enough python to write one myself. Any help would be appreciated. Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Is there a way to ...
Post by LeviFiction »
Have you tried "Save Copy As"?
And with a small bit of effort you could create a script that saves all open files to a specified location easily.
MikeFromMesa
System_Drive: N/A
ram: 16 GB
LeviFiction wrote:Have you tried "Save Copy As"?
Save Copy As does seem to remember the last save location. I tried Save and Save As but thought Save Copy As would act the same way.
Thanks for the help. I may still look into python but now there does not seem to be such an immediate need.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
I'm never sure I understand the question, so here we go:
If you want to 'save as..." files to one folder you can add that folder to a list in the save as dialog.
To the right of the folder drop down you see 5 buttons; the rightmost is a folder with a black triangle pointing down. Click on it.
There are two standard folders in the drop down, psp and my pictures. You can "add current" folder to that list. To remove an added folder, go to it and click "remove".
Again, if this isn't a workaround for what you meant just disregard :)
MikeFromMesa
System_Drive: N/A
ram: 16 GB
Forriner wrote:Hi,
Thanks. I would not have noticed that small icon so your post was a big help.
I am not sure exactly what the differences are between Save As and Save Copy As, but now I have two possible ways to avoid all of that extra overhead. My guess, which I will have to test, is that Save As will tell PSP that the file has been saved and so there is no need for a reminder before closing the file while Save Copy As may not mark the file as saved.
As with Photoshop, I guess there are multiple ways to do the same thing. It just takes working with it and/or help from those who already have done the heavy lifting. Thanks again.
Forriner
ram: 16 GB
Post by Forriner »
Save as... (F12) changes the name of the file you're working on in the workspace if you type a new name while saving.
Save copy as... (Ctrl+F12) doesn't change the name of the file you're working on in the workspace. It's a copy under a new name.
That makes a difference for the name PSP suggests the next time you save as or save copy as.
If you do File/Save (Ctrl+S) or hit the Save button (if you haven't removed it yet;) on a new file (Image1 etc), PSP opens the Save as... dialog to name it. Otherwise it replaces an existing file without asking.
MikeFromMesa
System_Drive: N/A
ram: 16 GB
Forriner wrote: Otherwise it replaces an existing file without asking.
Unless, of course, you are working on a proprietary raw file, in which case it cannot save in that raw format. Then it appears to try to save the file in the Corel proprietary format.
Thanks for the explanation.
