Pink static images
jakev383
operating_system: Linux
processor: Intel i5
ram: 4GB
Hard_Drive_Capacity: 500GB
Pink static images
Post by jakev383 »
Not sure if this is a bug (well, pretty sure it is) - anyone else seen this behavior?
After upgrading from AS1 to AS2, I just pointed AS2 at the AS1 catalog (maybe my mistake?) Everything seemed to work fine, but I noticed that about 50% of the time if I try and browse to an "older" folder in my catalog, I get this:
Pink image
Pink image
If I exit the program and restart it, this will go away for a while.
Not sure if it's relevent or not, but I did upgrade cameras so I usually start the program looking at a CR2 for a 6D and the older images will be on a 60D.
I'm tempted to blow away my catalog DB and start over from scratch to rule out any upgrade issues.
Anyone else seen this behavior?
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: Pink static images
Post by df »
If you have Open CL acceleration turned on try turning it off.
Regards, Dan
dsigman
motherboard: ASUS A78M-A
processor: AMD A8 6600K
ram: 8 GB
Video Card: ASUS R7 250X
sound_card: AMD High Definition
Hard_Drive_Capacity: 1 TB
Post by dsigman »
df wrote:If you have Open CL acceleration turned on try turning it off.
It may be enough to reduce the level of Open CL acceleration. I was having the same problem and that seemed to work.
jakev383
processor: Intel i5
ram: 4GB
Post by jakev383 »
I do not have OpenCL enabled. I did try turning down all the acceleration options though (use 3 cores instead of 4, 1 I/O thread, and 1 batch item in flight).
I'll see how that does.
jakev383
processor: Intel i5
ram: 4GB
Post by jakev383 »
jakev383 wrote:I do not have OpenCL enabled. I did try turning down all the acceleration options though (use 3 cores instead of 4, 1 I/O thread, and 1 batch item in flight).
Crap. It's still doing it, but not as often maybe? I'll need some more soak time.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Make sure you saved the XMPs in the AS1 and then recreate the catalog in AS2.
cheers
afx
df
ram: 64gb
Post by df »
I'd be willing to bet that you have settings made in previous versions that are incompatible with ASP2. Noise Ninja for example is no longer available due to NN withdrawing their support. In which case afx's advice is the best course.
Regards, Dan
jakev383
processor: Intel i5
ram: 4GB
Post by jakev383 »
Thanks - I'll give that a shot. I want to rebuild my catalog anyway, since I moved a lot of pictures off to an autofs sshfs mount.
