Using levels after using black/white makes images blueish?
Kneops
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
I made a black and white preset for myself as good as possible, using the black and white plugin. After I do that and I check the checkbox in front of the levels, it makes the image blueish and not really black and white anymore, so it somehow adds a bit of color to the image. Is that 'normal'?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Using levels after using black/white makes images blueis
Post by afx »
Curves/Levels sits after the BW plugin in the pipeline, so it can be used on RGB channels for toning.
But Autolevels should not do anything in RGB channels, so this sounds a bit strange.
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Sorry, I meant curves.
This is before clicking curves: http://minus.com/lbbiqy1dkFiFxG
And this is after clicking curves: http://minus.com/lVduL2KNndMxZ
I assume I can also use curves with black and white images, like I do in Gimp.
afx
System_Drive: N/A
Post by afx »
Your curves look like they are not in Sync RGB wise...
Press the reset button on the curves and then perform the adjustment on synced curves.
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Thanks! That was it. I thought I clicked both reset buttons, but I must have clicked only the one on the right.
