Using Preset in outputbatch
mikmak
Post by mikmak »
Have now installed the newest version of AS2, just to find out that the problem from version 1 still persist with the latest versions of the plugins. When you use a preset with ztext, zframe & zshadow in the output batch it sometimes work with one image, but if you select more than one the batch stops and the program freezes. The last version where this worked was in the 1.0.1.10 release (which I still use btw).
Any solution to this problem ??
Regards
Per Thorup
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Re: Using Preset in outputbatch
Post by SteveCase »
Might try asking tintin in the plugin section of the forum. :wink:
Steve in Seattle,WA
mikmak
Post by mikmak »
As I see it it is not a plugin problem. The plugins works fine in the old versions of AS; but have not worked since the 1.1.0 update.
REgards
Per Thorup
