PSPX7 trial users
hwm333
Re: PSPX7 trial users
Post by hwm333 »
I am new user X7 and recently connected an Epson scanner. Downloaded and installed the Epson 64bit scanner driver. Under "Import", "from scanner or camera" my scanner is detected. However, under "Import", Twain Acquire" I get error message "scanner not found," I then try "source" with same result. Device manager shows the scanner; "Import" shows my scanner, but the TWAIN path does not. I think Corel has a problem.
OldRadioGuy
motherboard: Dell 0YJPT1 A00
processor: Intel Core i7-3770 3.40 GHZ 8 virtual cores
ram: 16 GB
Video Card: AMD Radeon HD 7770
sound_card: Realtec High Definition Audio
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung 23" HD 1920x1080 px
Post by OldRadioGuy »
hwm333 wrote:I am new user X7 and recently connected an Epson scanner. Downloaded and installed the Epson 64bit scanner driver. Under "Import", "from scanner or camera" my scanner is detected. However, under "Import", Twain Acquire" I get error message "scanner not found," I then try "source" with same result. Device manager shows the scanner; "Import" shows my scanner, but the TWAIN path does not. I think Corel has a problem.
Yes, you are correct. PSPX7 is not seeing the x64 driver.
I checked this with my Epson V500 scanner. Both PhotoLine and Paint.NET read the driver and open the the scanner interface. The x64 version of PSPX7 does not find the driver. A bug still not fixed.
Bob
Affinity Photo 1.5 | ON1 Photo RAW 2017 | DxO Optics Pro 11 | Aftershot Pro 3 | Olympus PEN-F cameras
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
64-bit PhotoLine?
Because, again, many scanners don't have 64-bit TWAIN drivers only 64-bit compatible drivers which means only 32-bit software can read them but they're designed to work on a 64-bit OS. The drivers mentioned could very well be 64-bit but it's rare.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
TripleHeinz wrote: [WISH]
- Implement what is indicated in red in the image and i'll marry PSPX7 (Japanese can marry video games, why can't i marry PSP?).
Meantime you can use one of millions tolls like - http://www.colorschemer.com/colorpix_info.php
ram: 6 GB
The Hex field exists inside the color picker in PSP.
OldRadioGuy
ram: 16 GB
LeviFiction wrote:64-bit PhotoLine?
I won't quibble over whether or not the driver is x64 or x32. In the case of my scanner, the driver was advertised for x64 systems. The real point of my post was that the x64 version of PhotoLine, an innovative photo editor+ from a small German company, and Paint.NET, a free photo editor developed by volunteers (only x64), will both recognize the driver and run the scanner interface.
The x64 version of Corel PaintShop Pro X7 version does not.
Bob
ram: 6 GB
That's what I wanted to know. Not to quibble over drivers, just that you had not indicated if PhotoLine was 64-bit or not. I could just make the assumption but, not to be insulting, I've seen people claim "my software can see it" when their software was 32-bit and so was the scanner driver.
I also haven't upgraded Paint.net in some time. It's still at version 2.4 on my system so I was unaware of the 64-bit mode that it uses on 64-bit systems.
OldRadioGuy
ram: 16 GB
LeviFiction wrote: It's still at version 2.4 on my system so I was unaware of the 64-bit mode that it uses on 64-bit systems.
It's 4.0.3 now
OldRadioGuy
ram: 16 GB
PSPX7 fails to render TIF from onOne Perfect Photo Suite 8.5.
I have been able to reproduce the rendering problem reported earlier. The image began as a raw file and was converted to a TIF. It was then opened in Perfect Photo Suite 8.5 with the option of save as a single-layer TIF file.
Here is that image reopened in Perfect Photo Suite 8.5:
Here is that TIF image opened in PSPX7 x64:
I also found the image failed to render correctly in ACDSee Pro 7. However, it opened correctly in PhotoLine 18, Paint.NET 4 and Photo Ninja 1.2.3b. All of these applications are x64.
Bob
GlenBarrington
motherboard: Lenovo Ideacentre 30020ISH 90DA
processor: Intel Core i7 6700 3.4 GHz
ram: 12 GB
Video Card: Nvidia GEForce GT 730m
sound_card: RealTec the rest unknown
Monitor/Display Make & Model: HP Pavilion 27 XW IPS
Corel programs: Corel PSP X8
Post by GlenBarrington »
OldRadioGuy wrote:PSPX7 fails to render TIF from onOne Perfect Photo Suite 8.5.
Bob
Bob, see my reply on the ACDSee user's forum.
ovalseven
ram: 2GB
Post by ovalseven »
TripleHeinz wrote: [DON'T LIKE]
- Title bar can save a few pixels by removing top padding.
I've always hated that too. There's no reason for the title bar to be larger than any of my tool bars. In fact, there's no reason to have the title bar at all. It's wasted space.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
I've added a button for Full Screen Mode to the menu bar so that I can quickly get rid of the title bar when I need to.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
ovalseven
ram: 2GB
Post by ovalseven »
Cool idea. Don't know how I missed it all these years. I just added one to mine too. Thanks for the tip.
I wonder if there's a command line you can add to the shortcut so it launches that way.
LindaSue
ram: 3 GB
Post by LindaSue »
You do lose the status bar when you switch to Full Screen Mode but you can also add a button for viewing it if you need it.
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Post by pdxrjt »
Good tip about the button for full screen mode.
Adverts for Corel products when you close PSP don't bother me.
