hartpaul wrote:zim wrote:
Only comments so far are that I like to use keyboard shortcuts (like + - for zoom in/out) but haven't found any for re-sizing the makeover (spot healer) tool. I use that a lot and sliders aren't my favourite. I can put the cursor into the size value box then use the up/down arrow keys but that's a little bit of a faff.
Regards
In all versions you can click to make the size active then roll your mouse wheel to change size.
You can also hold down the alt key and drag up to make the brush / blemish fixer smaller and down to make it larger.
This is also Broken in PSP X7 as it does not refresh quickly enough to show what size you have reached. You check the difference in X7 by changing the size of the Brush tool and comparing it with changing the size of the Blemish Fixer.
Thanks Paul, I had a feeling that was a bit of a newbie question
I've had a chance to go through more of the work processes I need (still got a few layering requirements to check) and I must say I'm very happy so far it's pretty easy stuff converting from PS.
There is a deal breaker for me though;
Must be able to embed ICC color profile for
OFFSITE independent color lab for printing.
Having looked at quite a few forums and googled the interweb this seems to be a right mess in PSPX# (Pease please feel free to discredit me on this!!)
I can set an ICC profile for an image to be printed to an attached local printer, that's fine, but not save an image with an embedded profile for external processing?
Is there a definitive answer to this issue please?
If not I'll just have to sadly move on even though my experiences so far make me really want to like this software!
Regards
